Question about Visonik VB212PKG Car Audio Amplifier
How do i hook up my amp. the ground wire and the v 12
    Scholar:
  • 84 Answers
Well, basically... the 12v (+) power wire is fused and hooked to the battery and ran to the amplifier, then run an amp turn on wire from you radio its usually blue with a white stripe (if you have an after market radio) then run the rcas from the radio to the amp and finally tap the ground (usually and cleaned bare-metal on your car close to the amp).... if you give me some more info i can help u further... what is the make/model/yr of your car, what radio do you have, amp, sub, speakers, etc....?
Posted on May 02, 2010
4 Suggested Answers
SOURCE: car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Posted on Nov 18, 2008
dushko
  • 59 Answers
SOURCE: using 12 gague wire on a 250 watt amp blowing fuse
The wires are not the case(I suppose). But you might want to move to 8 gauge(though 10 could be enough,but in Hi-Fi enough is never enough) , but 6 would be the real thing if it's 4x250W(sinus?) placed in the rear of a car(while the battery is in the front)than this is actually just a FAIR minimum. An upgrade to the battery's ground wire is to consider, too, must be thicker than the actual, so a 4-gauge I reckon?
But back to your question :) What fuse did it blow actually? Is it in the car's fuse box/ Is it inline on the wire between the battery and the amp?/ or is it the amp's own fuse(on the amp) ????
Posted on Apr 15, 2009
etirbynnor
  • 655 Answers
SOURCE: amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Posted on Jul 29, 2009
HOW TO WIRE E3EB-20 TO PANEL BOX
I'm just assuming that is 220 volt 20 amp The wire that is run is likely a common romex 12-2 NMD-90 Strip the 2 wires put red tape on the white wire as it is no longer a neutral. Hook both wires into a double 20 amp breaker. Put the ground wire onto a ground screw.
Nov 28, 2013 | Heating & Cooling
How many 100 watt light bulbs can I hook to a 20 amp breaker (120 volts)
A 20 Amp breaker will support 2400 Watts with a 120 Volt line.
120 Volts times 20 Amps (Amperes) = 2400 Watts.
Answer? 24 100Watt light bulbs.
HOWEVER, you should always allow 1 cushion of 100 Watts.
That would be 23 100Watt light bulbs.
(Wait until you add electric motors to the equation. Things start getting a little more complicated)
(I always use 20 amp breakers for lighting. 15 amp breakers for lighting is phased out.
Secondly a 20 amp breaker requires using 12-2 or 12-3 wiring. (12/2, 12/3)
SO does the receptacles.
Therefore 12 gauge wiring is used throughout the house, until you come to the heavier loads )
[ 12/2 = 2 insulated conductors, and one bare copper ground wire.
12/3 = 3 insulated conductors, and one bare copper ground wire.
Remember, with 12/2 the Black wire is ALWAYS the Hot wire. White is Common (Neutral). Bare copper is Ground wire.
12/3 has 3 conducting wires.
One Black, one Red, and one White for the Common. (Neutral) Bare copper is Ground.
Used for 3-way switches ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 30, 2011 | Hammering
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Jan 18, 2011 | Nitro BMW-483 Car Amp
When you hook up the wiring for the pump to the boiler, it is 120 volt, do you hook a ground as well.
Hello, for safety sake, you should always connect a ground to any equipment. I am assuming that you are running #14 or #12 guage wire to the boiler on a 15 or 20 amp breaker. If you are using a 14/2 or 12/2 cable, the ground wire will be included in the cable. Please do install the ground securely as this is for your protection and protection of your loved ones.
Jan 06, 2011 | Heating & Cooling
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
I have two 12 rockford fosgates p3 hooked up to and 350.2 kicker amp i just got them so i hooked them up and my amp will keep turning on and off
How may ohms are the p3's and how are they hooked up? Some amps won't handle less than 4 ohms bridged. Try running one sub to each amp channel.
Also check power and ground connections.
Useing too small of wire for power, ground can cause the same problem.
Apr 17, 2010 | Kicker ZX1500.1 Car Audio Amplifier
How can I install a horn in a battery powered golf cart? I have a 12 V horn and a button. Do I need more? Relay? Fuse? I'm no electrician so I'm not sure where to begin.
easy hook up.. the 12 horn should have 2 wires, a red and a black hook the red one to 12 volts with a 5 amp fuse in line, take the black and run it to one side of a push button switch (with 2 wires) the other wire coming out of the horn with go to ground, either to the battery ground or to the frame of the cart..
Apr 02, 2010 | Vehicle Parts & Accessories
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
Car amp blows 12 volt wire fuse
Jul 26, 2008 | Car Audio & Video
Car Audio & Video Logo
103 people viewed this question
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
