Question about Alpine Car Audio & Video
Do you know the pin/wiring for a alpine SWE-1900 Sub
3 Suggested Answers
  • 5 Answers
SOURCE: subwoofer
go to http://rockfordfosgate.com/rftech/woofer_wizard.asp to find the best wiring diagram for your subwoofer
Posted on Apr 27, 2008
Davaith
  • 56 Answers
SOURCE: I have a Alpine SWE-1000 subwoofer with no wiring diagram.
No i do not have a wiring diagram for this exact Speaker but this speaker is self powered yes?
This blue and white lead is your remote turn on lead, this allows the amplifier to switch on and off with the vehicle, instead of just being on all the time and drain your battery.
This wire should be spliced in to an accesory that turns on and off with the flip of the ignition switch. If you could It would be best to splice it to the radio turn on lead. On your radio, there is a lead that should be labeled remote if it is aftermarket. If it is stock then you have to use a volt meter and back probe a lead until you find one that switches on with the igrnition switch, you should get one with battery voltag(12v or more) and one a ground (.11) and one with battery voltage when on and no voltage when off(this is the one you want to splice in too.
Posted on Jul 19, 2009
I have an Alpine swe 1900 I need to know where is the plus the negative in the speakers left and right
answer is in menue , eg. bass treble balance if not use reset button while set has acc only
Jan 18, 2017 | Alpine Car Audio & Video
8" compact subwoofer not working it was installed
post more information about your amp. its likely the vibrations moved something in the amps, or buttons.
Oct 10, 2013 | Alpine Swe-1000 8" Compact Subwoofer...
My sub only works when I press on the cone.
Sorry to be the barer of bad news It's BLOWN
Mar 22, 2010 | Alpine SWE-1043 Car Subwoofer
Can I mix subs
You can, but if you wire them in parallel that is a pretty heavy load on your amplifier. It may even sound better to use one sub until you can get some more power behind them.
Rule of thumb, you can never have enough power! Check out my tips on wattage.
Mar 05, 2010 | Alpine SWE-1241 Car Subwoofer
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
I just want to know how to open the speaker so I can look at the voice coil and see if I need to soldier the wires
You can access part of the voice coil through the dust cap, but I think the leads you are looking for are usually run along the "spider" of the sub and will require complete dis-assembly to get to their destination on the voice coil. It is not impossible and I have successfully done this repair many times. You can start by following the leads from the terminals along the "spider" to check continuity. After they disappear into the frame you will however need to remove the cone/coil assembly from the frame to gain access, let me know if you need further info, as I may have a diagram of your sub, so let me know what brand/model it is if you need more info.
-Dynami
Apr 06, 2009 | Alpine SWE-1043 Car Subwoofer
I have this speaker and it dont work
You dont want to do any repair to that sub... take it to a trusted alpine dealer and see if it qualifies for warranty repair... unless you get a high end sub like orion hcca's or others of that quality you cannot repair them and should never attempt to... any repair you do to them will make them distort unless you have the proper tools and know-how to do it
Connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Mar 20, 2009 | Alpine CDM-7874 CD Player
Alpine sub pre outs
i know people dont like doing it this way but when in doubt, splice wires.
go to walmart and buy a crossover, splice your front or rear door speaker wire and wire in the crossover and also the door speaker. plug your RCA cables in and run them back to the amp.
most people with stock decks do this if they dont have sub out or amp out.
if u need more help let me know
Feb 18, 2009 | Alpine IVA-D310 Car DVD Player
Car Audio & Video Logo
437 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
