Question about Craftsman 25cc Gas Line Trimmer
Gas trimmer runs for a few seconds and then stops
My Craftsman gas tirmmer is about 3 years old. This season it is starting, runs for a few seconds and then stops. I did get it to run for about 2 minutes and then it stopped. Put new gas in and same result. It did sit for about 3 months with old gas in it between seasons.
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Craftsman weed wacker wont start
have you drained out all the old fuel and tried fresh fuel gas is only good for 30days in small engines
Jun 08, 2012 | Craftsman WeedWacker Gas Trimmer 25cc...
Hi, I have a craftsman 25cc weed wreck. always starts in first time(cold) then couldn't start second time; If starts in first time, after 2-3 minutes (engine warms up) engine automatic stops.
the warmth to the carburetor will cause dirt to expand inside causing this to happen. Usually after 2 to 3 years these caburetors are no longer good to use. A new one will be better to have to run your trimmer
Walbro makes these caburetors and nobody likes to service them for their size is small and the cost is far cheaper to replace than fix
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Runs on choke a little
sounds like the carburetor has gummed up a bit, and may need adjustments - or, the fuel pickup in the tank has come loose [i.e.: deteriorated fuel lines] - also, make sure your gas mix is FRESH. if your gas mix is more than 2 months old, dump it
Sep 19, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 34cc 4 cycle weedwacker will not start
Start by removing and cleaning the spark plug. The check out the screen at the exhaust port and make sure that it is completely free of carbon build-up. I never run my equipment out of gas at the end of a season, I usually add some fuel stabilizer to the gas and run some into the carb before shutting down for the season. Hope this helps and good luck.
Jul 10, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Trimmer starts immediately, then stops
How old is the trimmer? If still under warranty, Sears can fix this. If not, then my experience has been the problem is a bad coil. This is due to heat build up. When the coil gets hot, it shorts out.
Dec 04, 2008 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
633 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
