Question about Maytag Atlantis MAV6000 Top Load Washer
Won't spin. It agitates and pumps - Maytag Atlantis MAV6000 Top Load Washer
    Problem Solver:
  • 5 Answers
This could be as eazy as a saftey switch or it might be called a door switch or it is going to be in the brake assem if that is it repalce the washer good luck to you
Posted on May 02, 2010
5 Suggested Answers
  • 942 Answers
SOURCE: 110 92282100 kenmore HD80 won t spin.
Either the motor is trying to run and can't or doesn't start or the motor is running but the belt broke and so it is not transferring any power.
You will need to take a look and see which is the case. If I could hear the sound it is making I could tell you the difference, but hey this is the internet so you will have to do it.
Once you determine the cause you can do a search for appliance parts and enter your model number, the site will then give you exploded diagrams of your machine and a list of parts to order from.
  • The noise could be cause by a broken or defective shock.
  • Worn drum bearings.
Posted on Mar 31, 2010
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
  • 2468 Answers
SOURCE: ADMIRAL WASHER MODEL NUMBER LNC6753A71 HAS BURNING
its probably the drive belt that you smell burning under the basket,but there are numerous things that can cause it to burn,so you need to find where its froze up could be a clutch,the brake,the drain pump
Posted on Aug 02, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have a Kemnore 90 series washer that wont spin
Hello, Thats sounds like a broken motor coulpler,when its broke it will sound as if its agaitating/spinning yet it doesn't. The coupler is fairly easy to replace and this video will show you to replace it. The part number fot the coupler is 285753A it could be picked up from your local appliance parts store for no more that $20.00 or you could order it online from; assuredparts.com apdepot.com appliancepartspros.com searspartsdirect.com repairclinic.com Gene
Posted on Aug 08, 2011
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
