Question about Kenmore 22422 Top Load Washer
Cold water not working
Cold water doesnt work
    Problem Solver:
  • 5 Answers
I would check for a clogged screen or replace the water vavle good luck
Posted on May 02, 2010
I pull the start botton and it does not start or load water. and I don't know what is wrong with my machine.
ok lets see here,, first we need to make sure your timer is working, put it in a spin cycle and let it run and see if it shuts off ,, if it does your timer MIGHT NOT be bad try and see if it will fill with hot water, then warm, then cold,, if it fills with hot i is the cold side of your water valve, if it fills with cold its the hot water side of your valve,, if hot and cold doesnt work it could be your wter valve, or your pressure switch
Jan 19, 2011 | Kenmore Washing Machines
My heater stops working in the middle of the night. I have to get up to re set it but it turns off by the time i get back to bed. By 10 AM it starts working again on its own. its done this for 2 years and...
the Model number you gave is for a Shower Head what do you mean it doesnt heat... it only conrtols the water temp by BALANCING the hot and cold water inlets does NOT heat anything if your water is cold then check another PLAIN faucet to see if your water is the same temp( cold) if it is the hot water from water HEATER is cold nothing to do with faucets
Nov 22, 2009 | Kohler K-T462-X4V-CP Memoirs Rite-Temp...
Cold water cycle doesnt work, no cold water at all, just hot
Could be the cold water solenoid is stuck or broken, maybe a wire has broken or terminal worked loose.
You need to take a look inside and check the wiring, check the supply to the solenoid, etc. If the supply is good the solenoid is probably faulty. If there is no supply it is possibly the board or the controller.
Jun 18, 2017 | Maytag Legacy Series Top Load Washer
Hi, First check and see if there is something plugging the cold water inlet screen. Remove the cold water hose to look at the screen. Another way to test the inlet valve is set the washer to cold wash, listen for the inlet valve to buzz or hold feel the cold inlet fitting and see is you can feel it vibrating.
If there is nothing plugging the inlet screen and the inlet valve doesn't buzz, you will need to change it.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
NO COLD WATER
the problem sounds like an elecronic faullt try swapping the hoses over and also check that the resistance readings on the valves are the same.some times if they are diffrent it can damage the pcb.hope this helps
Mar 05, 2008 | Washing Machines
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
