Question about Daewoo DVRS04 DVD Recorder/VCR
How can I record from the vcr to the dvd
How to copy vcr tape to dvd
  • mksyed Oct 09, 2008
    I am using brand new blank sony DVD+RW to record program of basic TV channles to DVD on Daewoo DVRS04 DVD Recorder / VCR Combo machine. When I press record button and it shows " preparing DVD for recording please wait" and then it starts recording, record button on the machine goes red, after some time if I stop and want to see if the program has recorded , the disc shows empty. It does not give me menu option for Making compatible , or selecting title.
    I am unable to even copy from VHS to DVD.
    Please tell me if I am doing anything wrong
    Guru:
  • 1,463 Answers
On a combo unit ,insert the vcr tape and then put a blank dvd r /rw in to unit , you should then press rec button and records to dvd.
note you cant copy proteceted tapes due to the macrovision
Posted on Mar 25, 2008
SOURCE:
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
I just bought a Magnavox ZV450MW8A DVD/VCR Recorder. It has recording capabilities on both the DVD and VCR components but can you tell me if I can use it to record FROM the VCR directly onto the DVD? This...
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
Jun 13, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Not able to copy entire vhs to dvd
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Aug 10, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
How to copy VCR tape to DVD on a LG DVD/VCR recorder. Model LRV-517. Thank you!
Did it come with a manual? I would recommend reading it. If you don't have a manual I would order one from Toshiba. If it is anything like my DVD/Video recorder you just put the tape and DVD in and hit the "Dubbing" button. You can not copy Macrovision recorded tapes.
Aug 04, 2008 | LG Televison & Video
VHS to DVD recording
Yes, just turn off the tv.
Walt
Apr 08, 2008 | GoVideo VR3845 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
DVD Recorder+VCR
Are you putting in both media, starting the VCR you want to copy and then pressing copy? The first post mentions "set up" and that is not necessary for copying.
Jan 17, 2008 | GoVideo VR3845 DVD Recorder/VCR
Daewoo DVRS04 DVD Recorder/VCR Logo
515 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
