Question about Maytag Dishwashers
I have a Maytag Jet DWU9902AAB. We had a power outage and when power was restored the dry light was on and I can't get it to clear or do anything. I have tried turning the breaker switch of then on, but still nothing. Any ideas??
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
  • 958 Answers
SOURCE: Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Posted on Nov 26, 2008
  • 2318 Answers
SOURCE: totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Posted on Dec 03, 2008
  • 69 Answers
SOURCE: Maytag Epic Dryer has no power.
Maytag.com
Posted on Sep 20, 2009
RED92JEEPER
  • 51 Answers
SOURCE: Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
Posted on Sep 27, 2009
I have a Maytag dishwasher. I use Cascade and jet
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 15, 2010 | Maytag Dishwashers
We lost power last night and this morning the maytag jet clean dishwasher is not working, does not appear to have any power. Is there an internal circuit or something?
there are internal thermostats or even an internal type fuse kit..... it is also common after power outages when you regain power that , that sudden jolt of electricity enters or circuits again it blows out electronics.... if u have an electronic control you might have blown that control board as well hope this helps
Jan 31, 2010 | Maytag MDB9600A Jetclean II Built-in...
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
The dry button is lit, no other buttons will respond to touch.
try to unplug unit for 30 min if this doesnt reser then change the module/control board.let me know what you think
Mar 17, 2009 | Maytag 24 in. DWU9902 Built-in Dishwasher
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dishwashers Logo
51 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
