Question about Kitchen Ranges
The icemaker on my whirlpool refrigerator no longer operates well. Instead of cubes i end up with a huge block of ice that prevents the dispenser from turning. Do i have a leak somewhere? The serial # is S63345799 Model#3VED29DqEW00
  • kmorgan57 May 02, 2010
    I meant the one that kicks the ice into the tub. I do get some cubes but I also get a block of ice in the tub and thats whats preventing the dispenser from turning
    Thanks, useful advice
  • 674 Answers
Do you mean the ice dispencer in the door or the one that kicks the ice cubes into the tub inside the refrigerator.
Posted on May 02, 2010
  • 1 more comment
  • Brian Niten May 02, 2010
    The valve that lets water into the icemaker could be leaking. This would cause too much water to fill the icemaker tray and possibly overflow into the tub.
    You should also check the temperature setting for your freezer to make sure it hasn't been accidentally turned up.
    You're welcome. Thanks for the vote.
The ice maker makes ice for awhile and then clogs up with ice. How can I prevent this?
It's possible that the system is either no longer sensing that its ice reserves are full (if I am reading your question correctly) or that the water supply to the icemaker isn't shutting off, instead slowly drip flowing over the ice cubes until they solidify into a continuous glacier. I recommend thawing the icemaking system out and cleaning everything up with a bleach-water mixture, then testing your sensor and water supply.
Aug 04, 2015 | Kenmore Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
