THis could be one of the CRTs (Color Tubes) is bad or the high voltage is leaking somewhere.
Toshiba projection TVs have history of yoke problems.
My guess is one of the CRTs is arcing inside. This TV has 3 CRTs red, green and blue. Replacing a CRT is not easy or cheap to buy if you can find it. If you like this try calling a TV technician to track down the high voltage arcing. DO NOT TRY TO DO THIS BY YOURSELF.
Hi, Symptom shows tv got problem with green picture tube that need to be replaced. Rear projection tv has 3 picture tubes, red-green-blue to make color picture. Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can. Thanks.
The picture tube is starting to fail. The increased screen voltage allows it to stabilize at the expense of color quality. Sorry to say, but it is time for a replacement.
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
The screen becomes distorted briefly when the popping sound occurs.
