Question about Microsoft Xbox 360 Console
Half red ligh starts blinking then shuts off
Hi, I start playing the on the lft side of the power switch a half of a red ligh starts blinking, the fan starts kicking on then it shuts down? Whats causing this.
  • 767 Answers
Two possibility , first the 1of the heat sinks may have lost it's thermal seal
to the chips ie G.P.U. or C.P.U. this is more common when consoles
are played vertically . Second but less common the G.P.U. temp feed
connection has become intermittent and tripping a thermal shut down.
Remedy's are
Remove heat sinks for G.P.U. and the C.P.U clean off the old heat sink
compound and replace with new ( articsilver 5 ).
If the console still over heats ( two red lights) then the G.P.U C.P.U
will need to be re-flowed back to the board that normally corrects
the problem in 90% of over heating problems.
If you have any questions feel free to ask.
Rob
Posted on May 02, 2010
TV shutting off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 10, 2014 | Sony KDF-E55A20 55 in. LCD Television
I was playing Cod4 online, when it froze for a second, red light came on the console, and the console shut down. Now when i try to start up again, the fan comes on for a second, along with the normal green...
Check ur console first, then test the hard drive, then unplug the console from the wall for about half an hour and then plug it back in. The next step you can do to fix red light of death is to see if you still have a valid warranty for your gaming console and then Go online to expert sites which will show you some online programs that will fix PS3 red light blinking in just an hour better u download repair guide
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
My ps3 wont turn on
Hi There,
Your Processor needs reflowing (re soldering on the board) as the system over heated, it caused stress on the solder joints underneath.
Sony charge £150 and give a month warranty to repair it.
We charge £60.00 and give a 6 month warranty.
FixMyConsole
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
PS3 won't power up.
THis issue is a motherboard issue, sort of like the 3 red lights on the Xbox 360.  It will need to be repaired.  If it is under warranty then send it to Sony, otherwise we fix this issue in my repair shop, just go to joegoods.com
Apr 02, 2009 | Sony Playstation 3 (PS3) Console
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
75 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
