Question about Thermador 37 in. SGSX365 Gas Cooktop
All of the igniters are clicking with no gas turned on. When I turn the gas on, the clicking continues. Can't get the clicking stopped.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to clean everything with the help of blow dryer. Also make sure that the small metal piece that the spark comes from is clean and the holes in the burner are clean. To clean the holes you can also use a paper clip and/or a pin. If still the issue is not resolved then check the ignition switches under the control knobs as if they are broken can also cause clicking sound even when the burner is light. If everything else seems to be working fine then it seems that you have to replace the spark module. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 02, 2010
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
I have a Miele cooktop and often during ccoking another burner starts clicking and click for a long time......solutions..... Also the lower left burner goes on for may be 10 seconds while clicking, the...
I have the Miele km342g cooktop. The ignition would continue firing intermittently after the burner was lit - click, click, click. Drove us crazy for years and we cursed the unit every time we used it. We assumed it was sensing unburned fumes and so we bought a small fan to "whisk" the gas fumes away. etc. etc. I finally figured out what a simple little thing it was. To start the burner, you turn the knob counter-clockwise. Therefore, once the burner is lit it's intuitive to turn the burner down by turning it clockwise. But in order to turn the burner down, you have to continue turning it counter-clockwise - or, "counter-intuitive". Once we figured that out, we haven't had a problem since.
Sep 04, 2011 | Miele 36 in. KM342 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
Sep 16, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Ignitors continue to ignite on other burners
the igniter switch are stuck /need clean contactor of the igniter .
Jan 08, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Clicking sound whenever I turn on a burner
There is no problem. The click your hearing is the spark module igniting the gas. The clicking will only occur while the know is turned to ignite and will stop after your turn the knog to any other setting.
Jun 17, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Thermador 37 in. SGSX365 Gas Cooktop Logo
56 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
