Question about Kitchen Ranges
Oven will not heat up on model#CFEF320GSA aprox.
Frigidaire range
oven will not heat up on model#CFEF320GSA aprox. 22 months old
  • Kitchen Ranges Master
  • 43,501 Answers
If you have a gas range check out this tip...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
If you have electric then check this out...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 04, 2010
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
Oven Overheats Excessivley
U might want to replace the thermostat since it appears to not be working properly.
Jun 25, 2017 | Frigidaire Kitchen Ranges
Dead spot?
Hello
You said, We just moved into a house and the built-in frigidaire oven, model no: CFEB27S2AS1 bakes on only the low heats, 0 - 250 and high heats, 450 - max but does not heat (red indicator light not come on nor any heat) at mid-range. Is there something I am not doing, or does it need to be "rebooted", and if so how do I get to the power plug/switch as it is embedded in the wall?
To reboot just turn of off the breaker for 5 minutes and this will reset the system perhaps!
I hope this works for you and you are alright!
Before you invest money into this oven remember this oven is 10 years old!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old oven
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your oven,
How much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ovens you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Oven doesn't heat
Its are a wall oven or range???
Model number please
May 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire oven wont heat?
Wheely, more than likley it's the ignitor. Just check the burner and make sure there are no large holes, rust, etc. Part number is 5303935066. Easy job. Catriver..post back.
Apr 03, 2007 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
308 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
