Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My sony bravia KDL 40S200 goes into standby mode red light blinks four times then pauses then 4 more what does this code mean?
redhead7377
  • 51 Answers
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Posted on Sep 09, 2008
mistersony
  • 320 Answers
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
  • 58 Answers
the error code is triggered by the inverter fuses, which blow when the inverter fails
Posted on Dec 06, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
Sony Bravia showing 4 red blinks any idea what this means, fault?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 27, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The red standby light flashes in the code of 4 times then pauses then 4 times then pauses
Five times blinks to Sony Bravia is related with an IRK error. It is related to its main digital board. In most cases, the main board might need replacement. It will be best to contact the authorized service center for Sony. If you're sound in electronics, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Mar 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Dec 05, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
457 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
