Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi WS-65869 BLINKING GREEN LIGHT reset buttton will not correct problem, cannot turn tv on
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on May 02, 2010
  • garc3206 Oct 09, 2010
    how do you remove the plug?
Mitsubishi WS-65869 TV. I have no power whatsoever
If you do not have the service manual I can get you a link for a free online copy which contains a lot of information for free.
It can be either read or downloaded for free.
May 27, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
I have mitsubishi 65" platinum series plus tv model WS-65869. the power green light continues to blink for three days know, and will not reset.
I am assuming the television is not powering up and the only thing it is doing is showing the blinking green light.
Unplug TV from the wall and see if it will reset itself.
If unplugging doesn't fix the problem then you need to find out what is causing problem. First thing to check are the fuses. Second thing to check is looking for burnt resistors or bulging on top of capacitors. Something caused the TV to enter so called safe-mode.
TV's carry alot of voltage in them so BE CAREFUL and UNPLUG THE TV.
If you are handy with a soldering iron then you can save yourself alot of money. An average service call & repair is $300-$450.
Oct 07, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
TV will not turn on
capacitors in power spply bad they will be bowed on top may need 4 or 6
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
1,040 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
