Question about Church Plumbing and Heating Church Seats 9400C Elongated Open Front less Cover Toilet Seat, 000 - White
94 escort over heating
94 escort 1.9
had this car for a few weeks and all was well. took it for a ride today about 4 miles noticed the gauge was on hot when i got home. I poped the hood the fan was NOT running and the coolant resivor was full (never was before)...there is no coolant leaks and fluid level is good.
I let the car cool down and started it again and let it idol. about 5 min later it started to get hot...I looked under the hood and the coolant resivor was back down to normal but the gauge was still reading hot and the fan still did not come on....the fan moves freely and is not frozen...please help. stat,water pump, fan relays????I dont know where to start
thank you
Denny
  • 349 Answers
Electric fan could be bad or a blown fuse or relay for the fan causing it to not work.
You can take you fan off and take it to an advance or napa or auto zone and get the to check it out.
But check the fuse and relay and make sure they are not blown relay may be under hood
Posted on May 05, 2010
Burping noise from gas cap, and fuel irregularity once below 1/4 tank
theres two plugs on the fuel pump. one is for pump and one is for gauge if you take pump out of tank and put a volt meter on the two outer prongs in plug then the two inner two of them will read the same when yoou move the level up and down and when you put meter on other two it will change when you move level or the level part of pump isnt working correctly. my old tahoe did that and when it would get to a 1/4 of a tank i knew it was almost out of gas.
Mar 01, 2013 | Cars & Trucks
My 1986 yamaha vmax temp gauge wont work how can i test it
Hi, Frank and the usual suspects are:
1. Blown instrument fuse.
2. Faulty wiring or connector between the sensor and gauge.
3. Gauge sensor has failed.
4. The gauge has failed.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
temp gauge not functioning VMaxForum net
How to test your fan temp thermostat switch
http://www.vmaxoutlaw.com/tech/VMX12-Service-Manual.pdf
OEM parts for Yamaha
http://www.vmaxoutlaw.com/tech/owners_manual.pdf
Oct 11, 2012 | Yamaha V-Max Motorcycles
2004 Jeep Grand Cherokee temp gauge high when heat is on
If your "check engine" light is turn on, I suggest scanned the PCM to know exactly what fault code is stored there. Additionally, could be some problem with the "temp sending unit".
Keep us updated.
Jan 23, 2012 | 2004 Jeep Grand Cherokee
Just got my 2000 VW New Beetle with 3/4 tank of gas. Drove it 36 miles and its below 1/2 tank. Could it be the gas that they put in? Or something wrong with the car itself?
On just about every vehicle I have ever seen, the fuel gauge will move faster from 1/2 to 1/4 (I never let a tank run past 1/4. Bad for the fuel pump) than from full to 3/4 or 3/4 to 1/2.
Do a mileage check. Fill the tank until the pump stops, reset your trip or note your odometer miles. Dive a few days or a number of miles. Fill the tank again until the pump stops and not the amont it took to fill. Note the number of miles you put on and do the math.
Aug 27, 2011 | 2000 Volkswagen Beetle
I purchased a gas tank for my '07 Deuce and had it painted. The problem is that I did not notice that it does not have the bracket inside the tank for mounting the fuel level sender. Is there an option for...
To mount a fuel gauge in the tank, the left side "fuel inlet" must be designed for the sending unit and gauge. I'm afraid that there is no way to modify your tank much less without ruining your new paint.
Do like all of us old timers do, about every 150-200 miles, stop for fuel. Evidently your bike is equipped with a carb or you'd have a large hole for mounting the fuel pump and such. I'd put a Pingel manual petcock on the tank. They are worth the money and it may save you from a major headache in the future. If you're still running the original petcock, it is vacuum operated and will sooner or later get a hole in the diaphragm. Then you'll be stuck somewhere with a full tank of fuel but none in the carb. Put the petcock in the "ON" position and fill the tank. Ride until your engine runs out of gas and not the miles it took to do this. This is how many miles you can go before you need to find a station. I've got a '94 FXDWG that the fuel gauge quit many years ago. I've also been riding since 1966 and I never had a fuel gauge until I bought this bike. Old bikers rock.
Ride Safe
Steve
Feb 20, 2011 | Harley Davidson FXSTD Softail Duece...
My 1988 Ford Bronco 5.0 has been stalling / acting like its run out of gas. (Has always run great before) I know it has plenty. Today 7.28.10 It stalled twice, first time it did it had at least 1/4 tank,...
You might have what is called vapor lock. The fuel gets so hot that it boils in the fuel pump or the lines. Do this test spay water on the fuel pump to cool it off . ( this only works for a few minutes before it gets to hot and vapor locks again ) If you can Keep the engine heat Off the lines and the Fuel pump it might help. If you have metal fuel lines near a heat source rap them with something such as rubber fuel line sliced down the middle to keep the heat off them If you are using an aftermarket electric fuel pump relocate it down low near the gas tank ( they work better pushing than pulling ) away from any heat source such as exhaust If your using the stock fuel pump try replacing it with a new one it might be getting weak Replace the fuel filter while your at it.
Jul 28, 2010 | 1988 Ford Bronco
Going through alternators
Hi there, I am a girl (i.e. not car savvy), but I have a 1998 Altima as well, and the first time (4 months ago) I noticed the brake and battery lights on simultaneously, I took it to a Nissan service shop. Everything seemed fine until about a month ago when the symptoms returned. I ignored the problem for 3 days and the car just stopped running, period. Took it back to the shop, figured out it was a fauly alternator, got it sorted, no problem. Today (1 month after replacement), I see the same bloody problem, and I'm taking it back to the shop in the morning. I am wondering... is it the alternator, or something connected to the alternator that is malfunctioning? The 2 alternators put in were "rebuilt" since they didn't have genuine Nissan alternators available. I really hope the dealers aren't taking me for a merry ride.
Jul 13, 2010 | 1999 Nissan Altima
Overheating/No Heat 2001 Impala
change the thermostat and the temp gauge in the radiator
Mar 03, 2009 | 2001 Chevrolet Impala
Fuel gauge not working all the time.
This is a normal concern.
The instrument cluster uses 4 different operating modes to calculate the fuel level:
Anti-slosh (default mode)
Key OFF fueling
Key ON fueling
Recovery
After a fuel fill up, the time for the fuel gauge to move from empty (E) to full (F) ranges from 2 seconds to 55 minutes depending on which operating mode the fuel gauge is in.
The default fuel gauge mode is called the anti-slosh mode. To prevent fuel gauge changes from fuel slosh (gauge instability due to changes in fuel sender readings caused by fuel moving around in the tank), the fuel gauge takes approximately 55 minutes to go from empty (E) to full (F).
The key OFF fueling mode (2 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The key must be in the OFF position throughout the entire refueling of the vehicle.
At least 15% of the vehicle's fuel capacity must be added to the fuel tank.
The instrument cluster must receive a valid key ON fuel sender reading within 1 second of the key being put into the RUN position. The key ON sample readings are considered valid if the fuel sender reading is between 15 ohms ± 2 ohms and 160 ohms ± 4 ohms.
If these conditions are not met, the fuel gauge stays in the anti-slosh mode, which results in a slow to read full (F) event.
The key ON fueling mode (approximately 90 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The transmission is in PARK (P).
The key is in the RUN position.
In key ON fueling mode, a 30-second timer activates after the transmission is put into the PARK (P) position (automatic transmissions). When the 30-second time has elapsed and at least 15% of the vehicle's fuel capacity has been added, the fuel gauge response time is 90 seconds to read from empty (E) to full (F). When the transmission is shifted out of PARK (P), the fuel gauge strategy reverts to the anti-slosh mode. The key on refueling mode prevents slow to read full events from happening if the customer refuels the vehicle with the key in the RUN position.
Recovery mode is incorporated into the instrument cluster strategy to recover from a missing fuel level input during a refueling event. Missing fuel level inputs result from intermittent opens in the fuel sender or its circuits. Recovery mode (empty [E] to full [F] approximately 20 minutes) is initiated when the following 2 conditions are met:
The instrument cluster is in the anti-slosh (default) mode.
The actual fuel level in the tank is greater than what is being displayed by the fuel gauge
Feb 18, 2009 | 1983 Mercury Grand Marquis
Whirlpool Dryer not heating
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Church Plumbing and Heating Church Seats 9400C Elongated Open Front less Cover Toilet Seat, 000 - White Logo
52 people viewed this question
Top Church Plumbing and Heating Home Experts
Donni Steen
Tom Chichester
Are you a Church Plumbing and Heating Home Expert? Answer questions, earn points and help others
