Question about HP DeskJet 6540 InkJet Printer
Printing only in color
My printer just stopped printing in black. Test pages come out in color only. Changed the cartridge twice and it will not print in black.
    Genius:
  • 3,587 Answers
Hmm...maybe your print drivers went off line?
remove them, and go here for a fresh set
happens sometimes from power glitches
Posted on Mar 25, 2008
Black printing is fuzzy; other colors not printing
First thing you want to do is print the print quality test pages. Using the up and down keys and the enter key, you want to go through menus as follows: Troubleshooting>PQ test. This prints unique single color pages for each cartridge. If you a small amount of each color it is possible that you may have defective cartridges. As well, one bad cartridge can cause all the colors to not print. Yellow cartridges are bad for causing this. Have you recently changed cartridges in the printer? You may have gotten a bad one, it happens, especially if you are using refilled or 3rd party cartridges.
Jul 28, 2014 | HP LaserJet 3600dn Printer
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
I have a brother mfc 3240C. I have changed the
Apr 23, 2009 | Brother Office Equipment & Supplies
Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Apr 03, 2009 | Canon BubbleJet i560 InkJet Printer
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Changed color ink cartridge and prints in gray
Does it give the self test from the menu also in grey ?? if yes then then either the print carriage assembly has aproblem or the main board in that order.
If it prints fine in the self test then check the colour option in the printing preferences of the printer driver, they might be set inccorectly.Please correct them/
Happy Printing
Oct 17, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP DeskJet 6540 InkJet Printer Logo
79 people viewed this question
Ben Johnson
