Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Valve in Grohe kitchen faucet stop functioning. First hot flow was reduced when handle in hot position, while cold was normal. Then all flow reduced to a trickle in hot or cold position. I believe that water input to faucets is OK. All other home fixtures have normal flow and temperature.
  • 20 Answers
It sounds to me like sand or buildup in the cartridge. You should pull the faucet apart and clean the cartridge.
Posted on May 02, 2010
Testimonial: "I think that you're correct. Later I read Grohe's recommended cartridge replacement every 2-3 year. Seems excessive, but will replace it. Thanx."
Which is the good Commercial Hot and Cold Sink Faucet?
Comllenhas been producing high-grade commercial kitchen appliances from the beginning, and it never stopped seeking glory. Its products are praised by the users who think that the company focuses on performance and durability which most commercial kitchen owners want.
Especially the Commercial Kitchen Sink Faucets are the highlights of the company. One of its unique commercial faucets is the Comllen Kitchen Faucet.
The ease of installation is commendable as well as the single handle control. You can use one handle to control the water flow and the water temperature. The handle makes your work a lot easier when you have your other hand occupied. The stainless design along with the brushed nickel finish is also noteworthy. The head can be rotated at a 360-degree angle allowing you to have options while working. It is a well-rounded product.
The Feature and Specification of Comllen sink faucet are given below:
Feature Analysis
360 Degree Head RotationThe head of the faucet can be tilted to 360° positions. So, you can get the water stream in any direction you want to.
One Handle ControlIt has a simple one handle operation. You can control the water flow as well as the temperature with this one handle.
Dripping Free TechnologyIn our Comllen Commercial Hot and Cold Sink Faucet review, we feel delighted to mention this unique dripping free system that reduces water wastage while helping to reduce energy bills.
Easy InstallationThe faucet can be mounted and installed pretty easily. It comes with a one-hole mounting feature which makes it easy for the user to install this faucet.
Specifications
  • Dimensions (L x W x H):15.8 x 7.5 x 2.1 inches
  • Adjusted Weight:2.85 Pounds
  • Colors Options Available:Brushed Nickel
  • Mount Options:Surface Mounting
  • Body Material:Brass
  • Handle Type:Single Handle
  • Body Design:Contemporary
  • Coating Medium of the Faucet:Brushed Nickel
  • Warranty Provided:Limited Lifetime
Mar 20, 2018 | Plumbing
Grohe kitchen faucet. I have good flow on cold water, but virtually none for hot water in Grohe bridgeford kitchen single faucet, is this a cartridge problem or worse?
try looking at the service valves located under the sink, the screwdriver slot should be in line with the flow of water,but some times the valve appears to work but it may have jammed shut even though it is in flow position,replacement is straightforward ,make shore the water is shut off elsewhere before removal.
Jan 28, 2014 | Home
I have a Grohe 32362 AVO bath faucet that began to show signs of slow water flow (both hot and cold). I turned the water supply valves off and then full "on" and then water flow ceased entirely? The...
hi, the fault is probably from a tempering valve, on the inlets (hot and cold feeds to the tempering valve) there are little filters that block up easily undo the connections to the tempering valve remove the filters and clean them
Jun 12, 2010 | Grohe Chiara Neu Lavatory Centerset ...
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Grohe bath faucet adjustments
grohe is a faucet all by itself ,,, I would recomend to have you call there repair dept. and explain this to them, you said you put in the new cartridge and thats about all there is to it, when you put on the handle make sure it is not over tightened, sometimes it pulls on the cartridge and makes it come on by itself good luck
Feb 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe LadyLux Cafe mdl # 33 758 single handle; w/pull out spray head - Hot & cold flow from faucet is minimal; at near by bar sink (same hot/cold feed) flow is fine. Suggests to me an obstruction in the...
There is a flow restrictor in the faucet. You have a very common complaint for these faucets. The restrictor will be shown in the owners manual. Remove the restictor. If you don't have the owner manual, work cautiously and take notes/pictures.
Phil
Dec 05, 2008 | Plumbing
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
610 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
