Question about Husqvarna Viking 1
Sews backwards not forwards
Were is the ajustment to make it go foward
  • 106 Answers
The timing is either 180 degrees out or you have got it in reverse. Look in your user manual
Posted on Mar 26, 2008
SOURCE:
How do I fix a serger that sews backwards?
move the sewing direction knob /lever to forward
Sep 27, 2016 | Sewing Machines
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
Model sw2145. Cant remember how to stop backwards sewing
The direction control Forward/Backward is located next to the stitch length control on the main vertical hoiusing of the machine. Lever up for forward down for backwareds.
Dec 04, 2015 | Simplicity Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Never used, just took it out of box. sews only in reverse. cannot get it to sew foward Please help. Thank you
often there is a button or a hook you have to push or pull out to get the machine to sew in reverse. Check to see if there is something like that that you could pop back into the normal position. Alternately in older models if you bring the stitch length adjuster past 0 it will begin to sew backwards so you could try that too. Good luck!
Sep 22, 2011 | Singer 3116 Simple
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Sewing Machines Logo
85 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
