Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Java issues java has some issues since java said to download the new version and then part way through the installation it quit, saying there was problems now when i try useing trend micro housecall virus scan which needs java it will not work
  • freedum Mar 28, 2008
    everytime i downloaded the new version all was good but when i installed java it said it could not finish then i manually installed it it says was a success but the problem is i like to run Trend Micro Housecall virus scan which uses the java platform it still will not work but thank you for your time
  • freedum Mar 29, 2008
    i did rate it the 1st time and the 2nd don't no what happened so thanks again
    Genius:
  • 3,587 Answers
Yeppers..java just went unsupported by MSoft, and now you need to get the fresh version from www.java.com
Posted on Mar 25, 2008
  • Patrick Michaels
    Patrick Michaels Mar 28, 2008
    so, the java issue was resolved? And then you went to Trend Micro(use it all the time) and then you say you are Not Rating my solution? hmmmmmm..perhaps you'll reconsider this action?
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    I cant get on pogo to play my games i downloaded java
    It's a ongoing issue with Pogo and Java. Java updates quite often due to security issues, Pogo has a hard time keeping current with Java. You didn't post your Windows version? 32 or 64bit? Try installing a older version of java, this is the 32bit version, it works with some of my clients Pogo issues: http://www.filehippo.com/download_jre_32/10808/
    Apr 19, 2013 | Computers & Internet
    Canon ImagePress C1 cannot calibrate from Windows 7
    The problem is it doesn't recognize Java 7. Install Java 6 (latest version) and it will work. You can have both Java 6 and 7 installed at the same time. As well make sure if you are running a 64bit machine you install the 32bit version of Java (so you will have 4 versions installed). Java 7 32 & 64 bit, Java 6 32 & 64 bit. I had the same issue and solved it this way.
    Jul 26, 2012 | Canon Imagepress C1 Color Copier,...
    Would like to download java
    site would be
    www.java.com click where it says free java then click where it says "windows 7,Xp, VIsta, etc"
    you have the option to do system check on line or offline (I prefer online) downloads pretty quick but install takes a while.
    give it a try
    Apr 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Internet will not play flash downloads..says java may be turned off...need a new flash etc.
    Generally resolved by loading the most current flash player from adobe.com
    if Java or flash error that they are not up to date, uninstall all previous versions from add/remove programs, reboot then install latest version again from Java.com or adobe.com for flash player
    Oct 18, 2009 | Acer Aspire 5315 Notebook
    Java Issue Wont work
    Open Internet Explorer>Tools>Internet Options>Security>Custom and scroll to see all of the Java enable check boxes. Check what you need, click on 'Apply', when it asks you are you sure you want to change security levels say OK! ~Steve Medley
    Nov 06, 2008 | Microsoft Windows XP Professional With...
    Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
    66 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
