Printer thinks new cartridge is empty-calls for replacement
Changed black cartridge with new & get error message to change cartridge
    Scholar:
  • 166 Answers
Please try to clean up the nozzles on the cartridge and take a dry piece of cloth ... try to clean up the slot/place where the ink cartidges is placed inside the printer.... if this does not work your printer has gone bad .... bcoz the slots has copper dots/nozzles
structure similar to the one's on the cartridges as they act as sensor .....
Posted on May 02, 2010
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
I have replaced all the ink cartridges and my printer says "no cartridge, open scanner cover"
It is probably best to replace cartridges individually as necessary. Let me explain. The printer display will tell you when a cartridge is "xx near empty" and when "xx empty" (where xx is the cartridge color).
1) Near Empty - you can continue to print. This message is to remind you to get a new "xx" cartridge and have it on hand.
Replacing the cartridge when "Near empty" will cause the machine to report "xx Empty" when it is not. It will not register that you have replaced it at "Near empty." Wait to replace the cartridge when you get the "xx empty" message.
2) XX Empty - you may not be able to continue printing. Replace cartridge "xx" now per your manual.
If you have replaced or reseated more than one cartridge, and you get the "no cartridge" error, you need to find out which one the machine "thinks" is problematic:
1) With the scanner cover open and locked in the "Up" position, the message may change to "Change cartridge, install xx" (xx refers to the color )
2) After changing the suspected cartridge and closing the scanner cover, be sure to notice the display. It will say, "Changed XX? 1. Yes 2. No" Press 1.
If all this explanation does not work, keep it in mind for next time. Brother says to unplug the machine for at least 10 seconds, then plug it in again. If the display shows the date and time, problem solved. If not, you may need to contact brother support.
Jan 22, 2010 | Brother MFC 420CN All-In-One InkJet...
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
Jun 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Change k toner error message
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
May 27, 2008 | Konica Minolta magicolor 2490MF Laser...
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
98 people viewed this question
k24674
