Question about Canon EOS 400D / Rebel XTi Digital Camera
Choosing to shoot Raw images
I have no choice in the options menu to take pictures in the raw format, i have a 4gb sandisk extreme 3 card in the camera, which has been formated, and works fine for jpegs.
  • VickiO49 Apr 05, 2008
    I have the Canon EOS Digital Rebel XTi EOS 400D camera and when I go to select the quality under menu/quality there is no RAW or RAW-JPG option to select. The highest quality I can select is L High Quality. Is something wrong with my camera? I'm using a San Disk 4 GB flash card. Thanks.
On my 400d, you need to be in one of the manual modes (P, Tv, Av, M or A-DEP) before being able to select RAW.
HTH,
Simon.
Posted on Apr 07, 2008
    Problem Solver:
  • 8 Answers
If you have Rebel XTi (400D), press Menu button.
Under the 1st Tab, the first option is "Quality" - select it. You should see 8 options from "fine L" to "Raw". Move selection using the arrow keys, and select RAW.
Posted on Mar 28, 2008
6ya staff
SOURCE:
Why am I no longer able to set my 60D camera to take RAW formatted pcitures
In order to select RAW mode, first check if your camera is in either Manual(M)/(A)/(AV)/(Ev) modes. Then go to setting-picture format-RAW/RAW+Basic.
In order to edit the RAW picture, you need to update the RAW version if you are using Adobe Photoshop for editing your pictures.
Thank you!
Regards,
Pratish Shrestha (pratis010)
Jun 27, 2014 | Canon EOS 60D Digital Camera
What does raw+fine pictures mean?
The raw+fine setting indicates that your camera will take both raw (NEF) and high resolution JPEG pictures with every shot. You can change this to shoot just JPEG or just raw shots using your menu under the little camera icon. Click on image quality and it will give you multiple settings so you can choose only raw or only JPEG. You have three JPEG settings: fine, normal or basic.
I always shoot raw+fine which I think may be the default setting. I use the jpeg pictures for simple and quick editing and I use raw for detailed editing. JPEG pictures deteriorate quickly during editing while raw pictures can handle extensive editing without significant deterioration.
When you shoot raw+fine, it means the camera is actually storing two pictures of the same shot, one in each of the two formats. When you view the pictures in Windows, you can tell the difference between the raw shots and the jpeg shots because the raw shots have a broad black bar across the top and bottom of the picture while the jpeg shots fill the screen.
Apr 14, 2013 | Nikon DSLR D90 Digital Camera
I am shooting in raw i cant download pictures properly or get my pictures printed off the the card
RAW images are what it means. You should convert them into a printable format such as JPEG before you can take prints. I strongly suggest that you shoot in JPEG mode to avoid all these headaches!
Apr 04, 2011 | Canon EOS 550D EOS REBEL T2i Digital...
Camera will not take more than 11 pictures with a 4gb memory card installed. I have formatted the memory card.
Sounds odd.
Check the memory card after format. Format with a flash card reader then do a right click on your mouse to check properties. Do you actually have 4gb available now?
Check to see that you're not shooting in RAW but that shouldn't eat up 4gb of space.
You can also use chkdsk to see if there are bad sectors on your card.
Jan 04, 2011 | Nikon Coolpix S3000 Digital Camera
The camera will only let me take about 7 pics before saying the card is full
Try formatting the card, It probably contains files that are not deleted. You format the card in the setup menu. Make sure you have saved all images to the computer before formatting.
Jun 21, 2010 | Fuji FinePix S9500 Zoom Digital Camera
When shooting large jpgs, the card seems too slow to keep up and for a couple of seconds reads busy. why?
Check your camera for bent or broken pins where the card connects.
Failing that, take all photos off the card and format in the camera
If that still is no good, make sure you have not set the camera to RAW + Jpeg ( 2 files paer image )
See if you can borrow another card to see if the fault is in the card or camera, it may be you need to buy a faster card for those shots.
Jul 02, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
I'm trying to recover 155 RAW photo images from my Lexar sdhc 4gb memory card .I'v tryed 2 differant photo stores but they could not help me ...we could look at the images but not get them off the card or...
you can try this memory card recovery software called asoftech photo recovery that helped me before
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Sep 19, 2009 | Lexar Professional High-Speed 2GB Secure...
Canon g9 camera doesnt work in raw only jpeg
Go to the menu for the camera and look for "SAVE". you should have the choice in which format to save the pictures. Select "RAW" and then exit the menu. The camera should now save in RAW format. Some one or something probably switched the setting (such as reset camera).
Jun 13, 2009 | Canon PowerShot G9 Digital Camera
Memory chips
you need to adjust down the resolution you are shooting in. Fine JPG vs RAW makes a big difference on how much memory goes into each image. RAW will mean more data in each image, but fewer images will fit.
Jun 06, 2008 | Olympus EVOLT E-500 Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon EOS 400D / Rebel XTi Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
