Question about RCA 27F530T 27" TV
My tv has picture but no sound is there a part that i need to replace?
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
TV STAYS ON WITH SOUND AND PICTURE FOR ABOUT 20 SECONDS .THE SOUND AND PICTURE GOES OUT FOR APPROX. MINUTE ,THAN THE SOUND AND PICTURE RETURNS .THIS PROCESS HAPPENS OVER AND OVER
It is symptom of weak lamp that has been reached to end of its working hours life and need to be replaced to solve this problem.
Replace lamp in your tv, procedure is easy and would be written in your tv user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Nov 21, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Tv has sound but no picture
the problem is from your picture IC. The picture IC of your TV is faulty and need to be changed/replaced for your TV picture to display again.
Good luck.
Mar 11, 2010 | Televison & Video
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Model # F32649- TV has static, no picture no
RESOLDER LOOSE CONNECTION IN THE TUNER OR YOU NEED TO REPLACE THE TUNER
Aug 23, 2009 | Televison & Video
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
No picture or sound on 42" plasm TV
Try unplugging tv and then plugging tv back on if that doesn't work then you will need to replace the signal board
Jul 06, 2009 | ViewSonic VPW450HD 42 in. HD-Ready Plasma...
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
TV working, then suddenly no picture, no sound
could be flyback transformer cracked need replaced 48.00 for part or board replacement usually done at about $200.00 , part number is 9-2022
Nov 24, 2007 | Zenith A25B33W 25" TV
RCA 27F530T 27" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
