Question about Sony KP-48V90 TV
Flash focus is not alighing correctly. the blue color is off.
    Top Expert:
  • Sony Master
  • 14,553 Answers
If the model number indicated is correct you will need to replace both of the STK-392-150 Convergence IC chips this set uses.
This can be a do it yourself repair if you are handy. The repair would involve getting at the two parts, being able to un-solder and replace both soldering the new ones in.
Total parts cost should on for example EBAY be under 25 dollars.
If this sounds like something you can handle let me know and I will give you basic instructions.
SD TECH
Posted on May 02, 2010
Testimonial: "hi... getting the info on the convergence chips you mentioned below would be great. can you send it to me? morrismmm@optonline.net thx morris If the model number indicated is correct you will need to replace both of the STK-392-150 Convergence IC chips this set uses. This can be a do it yourself repair if you are handy. The repair would involve getting at the two parts, being able to un-solder and replace both soldering the new ones in. Total parts cost should on for example EBAY be under 25 dollars. If this sounds like something you can handle let me know and I will give you basic instructions. SD TECH "
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Won't focus colors .. can see blue red green seperate ,, tried auto focus did not work
colors won't focus and I tried using auto focus. How do you correct the problem? How do you adjust the tubes?
Jan 06, 2011 | Sony KP-61HS30 TV
Model #65swx20b the magic focus can<t aligh the blue. picture has blue on side of peoples faces.
This is a convergence problem that can be as simple as bad connections at the convergence ICs or defective ICs. If you can solder, you should be able to fix this yourself. Let me know if that is the path you want to take and I'll provide more details.
Thanks,
Dan
Sep 10, 2008 | Televison & Video
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
Dec 31, 2007 | Samsung HC-P4752W 47" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-48V90 TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
