Question about Ruud UBHC Air Conditioner
Air conditioner keeps flipping the breaker
I am having a problem with my RUUD air condintioner unit. It keeps flipping the breaker switch and the unit stops working. It just blows out hot air. I can reset the breaker and the air conditioner works fine for about 25-30 minutes and then the same thing happens. I noticed that there is not water coming from the white condensation pipe. I replaced the filter to see if that solves it, but it is blowing out cool air. Is there anything else I can do? Thanks,
Darrin
    Novelist:
    Champion:
  • 246 Answers
Could be a lot of things. About the only thing you can do besides calling a service tech is to 'make sure your coil on the condenser (outside) is clean. This coil can be cleaned with a water hose, but you need to make sure you have all electricity turned off.
Turn off the breaker on the outside unit (this could be a fuse block that you have to pull out) and make sure you have your inside thermostat in the off position.
Once you are 'absolutely sure' that you have all electricity off - you can wash the coil with a high pressure hose. Just make sure that both - the inside and outside of the coil is clean; you may have to disassemble the unit a little bit, i.e. take the top off or one of the sides, etc.
The only hope you have - is that the coil is clogged and causing the compressor to overheat and go off on amp overload. It's possible this is the case - but I also suspect the compressor is electrically breaking down which is not connected to the condenser coil being dirty, in which case you will need a service tech and may be faced with some expensive repair. Let's hope this is not the case.
So - it's worth a shot to wash the outside coil.
Not to be 100% negative - it's possible it's something minor and when a service tech looks at it - it could be a fairly cheap repair bill.
Good Luck!
Posted on May 04, 2010
Where is the lockout switch on the ruud home air conditioner located
breakers & or fuses are used. some units have a switch if you have a panel off it wont run. some have a float switch in auxillary pan that shuts off unit.
May 27, 2014 | Ruud Heating & Cooling
Furnance comes on but the air stop getting cold just blows air ....what could be the problem
It sounds like it could either be low on refrigerant or the compressor has stopped working. Start by verifying that all the breakers and controls are in the on position. If the outdoor unit is running but you have no cold air, you may need a HVAC company at this point.
Sep 08, 2013 | Ruud UBHC Air Conditioner
Outside Ruud Achiever series fan not running. Furnace and thermometer are working but air conditioner will not come on. Please help- I'm hot :)
Hello Hottie,
start by verifying that the outdoor A/C breaker is in the on position. If it is then there is a problem inside the unit (most likely a split capacitor failure) and you should have an HVAC company help you out because that is HIGH voltage.
Sep 01, 2013 | Ruud UBHC Air Conditioner
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
Does a ruud achiever 10 have a fuse as part of the unit, seperate rom any breaker or shutoff switch
Hello, there is a 3-5 amp fuse located on the control board of the Furnace, it is located in the blower compartment. If this fuse is burned out, you have a short in the low voltage circuit,
Dec 22, 2012 | Heating & Cooling
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
Outside hvac unit
Check the breakers at the main panel flip them all the way off and back on. If this doesn't help check the outside breakers or diconnects near the units for power. Some disconnects have fuses or breakers so you may need to check these for power also.
Jul 29, 2010 | Ruud UBHC Air Conditioner
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
Ruud UBHC Air Conditioner Logo
464 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
