Question about RCA Televison & Video
Intermitant flashing red light, where it's usually green when on.
T.V will not turn on manually or with the remote. When I unplugged and then plugged back in it stays green for moments and then flashes red. Any advice?
  • cbiagi May 02, 2010
    Cheers Ginko, I'm going to give that a try. I feel we may have had a power outage this morning, after I left for work. It seemed to be working fine before that. The TV isn't very old, so I was hoping it had to do with our satelite remote, it acts up occasionally. They felt it was a television problem also. I'll get back soon. Thanks.
    Yes and it makes sense. Thanks.
  • RCA Master
  • 19,396 Answers
Hi.
If the TV goes suddenly in standby, and the red light stays on flashing, that means that the main controller board detected a fault condition (eg. a wrong voltage or a short), and turned the TV in standby to prevent further damage to internal component.
In this case is said that the TV goes in protect mode (forced standby).
If you have not turned the TV back on yet, follow the troubleshooting on article below.
My television does not start up
If your TV turns back on, and fail again at random time, it can be a faulty PSU, a faulty digital board. If TV is a CRT, the flyback converter is a common fault.
Regards.
Posted on May 02, 2010
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Lost Dynamic Falcon Mini Copter Manual/Instruction. What Does Flashing means while charging and why the green light isn't on?
The flashing red light means the batteries are low. The green light goes off when it's finished charging, or when there's not enough battery left to charge it.
Dec 21, 2010 | Atlus Video Game Consoles & Games
I have an iPod Touch 4 with iOS version 4.1 It has been working flawlessly for 2+ months. Today when I shut my B&W off (while the iPod was docked), I got the flashing red light. I unplugged the...
these all relate to the power supply, sometimes when the board is faulty the aux works fine, the red light flashing may only occur when the ipod is connected, but it is all part of the same known problem. contact seller or b and w service, they should fix it.
Nov 01, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
LG flat screen wont turn on. Ive tried unplugging from wall
The flashing light indicates the TV is in protection mode. Most likely logic board. Not sure what your model is but its usually the board that has your digital inputs in it ex HdmI etc. Post your model and you should get some one to post more info Ex ( LG XXX has a common problem with tuner board)
Oct 16, 2009 | LG 42LC2D 42 in. LCD HDTV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV will not turn
Please unplug the tv for 30 min and then plug it back to power supply and see if the lights are blinking again...
Good luck......
Jul 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Televison & Video Logo
217 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
