Question about Maxent MX-32X3 32 in. HD-Ready LCD Television
No power to tv
Cannot turn on the power switch to tv
  • Maxent Master
  • 8,457 Answers
U check ur power source with other electronic devices?Yes than ur power supply board is dead.Replaced the power supply board will fix the power problems.Tries Website like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 02, 2010
Neither the remote or power on/off switch works to turn on
I'm assuming you tv doesn't turn on but you have the red light indicating power , it's possible you have more than a faulty switch , common fault is the power board has blown one or a few capacitors , you could try replacing the power board on the tv but some tvs will not start if there are other faults , namely faulty inverter , faulty power board , if the display is faulty , it'll be cheaper to buy a new tv
Sep 19, 2014 | Toshiba REGZA 52RV530U LCD TV
Power Light stays Yellow
sounds like you have a power issue, or maybe the power switch is faulty. check that.
Jul 17, 2008 | Vizio L32 32 in. LCD HDTV
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
Reen turned wite with power only v8.03.6
From the remote select menu and reset the settings to factory default. It might become alright. Else, switch off TV manually, switch off power, remove plug and retry after 48 hours.
Aug 01, 2012 | LG 42LE5400 42 in. LCD TV
Why does our TV go through the channell setup everytime we turn it on?
Hi Mary -
The first thing you should do is consult the set up procedures on Page 8 / Section 4 of the manual. This will assure that you have completed and exited this important section properly.
If the TV should lose power (power outage, blown fuse or circuit breaker, cord removed from the outlet, etc.) the TV will likely need to have the setup performed when powered again for the first time. Likewise, a TV that is plugged into an outlet controlled by a switch, will lose power when the switch position is changed. Since switched and un-switched wall outlets look the same, you will need to unplug the TV and plug in a table lamp or similar and operate switches to see if it goes out. You will need to try both the upper and lower outlets as they can be operated independently of each other. If you find that the outlet is switched, you will either have to stop using the switch or find another un-switched outlet to power the TV.
I didn't see it mentioned in the manual, but some TVs have a dedicated power and a dedicated on / off button. If the power button is set to off, the TV will shut off and the remote will not be able to turn the TV back on until the power button is turned back on. The on / off button on the TV allows the TV to be turned on and off with the remote - or the on / off button on the TV. Again, this will only work if the dedicated power button is on. If the power button is set to off, it may be causing the TV to lose the set up information - requiring that it be done again. Make sure that you are using the remote to turn the TV on and off - or the correct button on the TV if you do not have a remote.
If all fails, you might want to contact Sanyo directly. According to the manual, they can be reached at 800-877-5032. I hope this helps & good luck!
Jul 31, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Protron PLTV-32 Television
Click tv on but nothing happens stand by light blinking
Check to see if there is an alternate power switch, my TV has (2) power switches, one turns the power on but not the TV and the other turns the TV on as long as the power switch is on.
Apr 22, 2010 | Sony FD Trinitron WEGA KV-27FS210 27" TV
M LTV-32HBG
We have a Model LTV-32BG that has power switch problems as well. The tv will turn off on it's own & you have to use the power switch on the back of the tv to get the green light on the front of the tv to "blink" again, or in otherwords be ready to turn on. Today in fact, the tv has turned off so much that I have given up on watching tv...
Apr 01, 2008 | Astar LTV-3201 32 in. LCD Television
Maxent MX-32X3 32 in. HD-Ready LCD Television Logo
111 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
