Question about KitchenAid Washing Machines
How do you remove the timer knob for a kitchenaide Model washer KAWE677BW1
  • 273 Answers
I believe that comes off by holding the dial firmly and turning the knob counterclockwise. The dial should pull off. Be careful, I think the dial is an obsolete part.
Posted on May 02, 2010
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
How do you replace the timer in a Kenmore Washer Model 22622?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
HOW TO REMOVE TIMER KNOB
its very well descised you have to pop out the middle plastic part in the middle of the knob behind it you will find a small clamp from there its easy sailing
Apr 27, 2010 | KitchenAid KAWS750L Top Load Washer
KitchenAide washer keeps agitating in the rinse cycle-will not mo
It sounds like there is a dead spot in the timer. The timer is the control device behind the large knob on the right. The timer part number for you machine is 3955761 and runs about $150.00 for the part.
Apr 20, 2010 | KitchenAid KAWS850LE Top Load Washer
Can't remove control timer knob on kitchenaid washer
The shaft go'es all the way thru the timer on most and you can keep it from spinning there.
Mike
Oct 16, 2017 | KitchenAid Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kitchenaid superba washer stopped working while in use. possibly timer. not sure how to remove timer box.
The timer knob on the front of the panel have to be removed. It unscrews, counterclockwise. If there are any plastic discs behind it, they will also have to be removed (by pulling off). This will expose the two screws which hold the timer in place.
If the timer knob doesn't unscrew and spins freely, the shaft leading into the timer is dislodged (permanently). You will have to destroy the timer to get to it. Remove the backplate by twisting straight the bent metal pieces which hold the cover in place. When you get to where you can see the shaft you will have to destroy the plastic which surrounds it to get to the shaft ifself. A pair of vice grips and a "I don't care if I destroy it" attitude is helpful. Once you get to the bare metal shaft you can hold it with vice grips and unscrew the knob to expose the two screws which hold the timer in place.
Jul 11, 2008 | KitchenAid Washing Machines
Kitchenaid top load washer
could be either take out the two screws at the base of the control panel and raise it up after you back the screws out pull the panel forward then lift it up its on hinges check all the connectors next you will see a black plastic piece in the center of the timer pry it loose with a small screw driver till it extends but is not all the way off this will release the control knob make sure the inner ring is on the shaft properly then posh the knob on tight and push the plastic tab back in if that doesn't fix it replace the timer
Feb 13, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
82 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
