Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
BELKIN ADSL WIRELESS MODEM ROUTER
I AM HAVING PROBLEMS SETTING UP TO MY LAPTOP SO IT REGISTERS AS MY MODEM SO I CAN RUN THE START UP DISK
  • Louie  Role
    Louie Role May 11, 2010
    What is the brand/make and model of your laptop pls? Does the laptop uses a built-in wireless networking card or an external/add-on? If n external/add-on, what is the make and model? Additionally, what OS are you using? Further, is the Belkin connected to an active ADSL account from your ISP that you have used/verified before?
    Pls post back with the information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Hi again,
Any new development(s) or updates with your concern?
Posted on Apr 08, 2008
I need help with belkin n150 model F7D1401 V1 ..i can't connect to my network..i have a Huawei SmartAx Mt 882 modem..and i want to connect my network, wich is an ADSL one, to my computer..I can't...
Your MT 882 modem most likely has a DHCP Server that will interfere with the ip address of the router. Did you plug the Router directly into the laptop then go to dos prompt and type in ipconfig/renew . Or reboot the laptop !
Then type in 192.168.2.1 into browser
You need to work out the IP address of your 882 modem and then change the dhcp server leases on it to start at 20 like it might be 10.0.0.1 to 1.0.0.254 or it could be 192.168.1.1 to 192.168.1.254 .
if you are planning on using both devices on the network !
Make the Modem DHCP start at 192.168.2.20 to 192.168.2.254 and then make the Belkin router / modem ip address be 192.168.2.2 and the 882 modem 192.168.2.1 if you plan on using the two devices together on the network disable the belkin dchp server.
if you are using just the belkin then the reboot or ipconfig/ renew will be all you need .
Apr 25, 2017 | Belkin Basic Wireless Router
Hi , plz guide me to connect my laptop to belkinRouter.
To begin with connect the Modem to the Cable/DSL/ADSL slot on the router and connect the computer to the LAN slot. Now run the disk given with the router. Enter your ISP settings and your internet would be working wired and wireless. Now connect to your wireless network using your laptop/wireless computer. Find the belkin network and connect to it.
Hope this helped.
Jan 23, 2011 | Computers & Internet
Belkin ADSL modem F5D5630au4 keeps losing conection
are you running filesharing? sometimes too many connections at once will cause the modem/router to crash and reboot
Oct 18, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I'm having issues with the belkin F5D7234-4 and intermittent connectivity with the network, i'm running a compaq c502tu and the belkin G/G+ router, which the router is hooked up to a general custom built...
Of the Belkin Modem Routers I have used and supported, around 60-70% had connectivity issues.
If the Belkin was cabled there appeared to be less issues than if it was used in a Wireless and cabled capacity.
I suggested to another person only moments ago to quickly sketch a diagram to show, how the network is set up. Add labels to the piccy's which provide the following info:
1. Computer Types (Makes, Models) and OS (Vista, Windows7, Leopard etc...)
2. Connection Types (Wireless / Cabeled).
3. The IP Nos.
4. Modem Types (Make, Model). ie, Belkin F5D7234-4 Router.
5. ADSL or ADSL2.
If it is possible to upload the diagram to FixYa then I suggest you scan the diagram (sketch) or take a photo of it and put it on the computer so it can be uploaded to FixYa.
I only discovered FixYa yesterday and joined, so I am not sure what is possible yet, as I have been focussed on trying to find solutions or provide suggestions on where to find the solution.
I would be proactive and submit your problem directly to Belkin via their website, I have provided the Australian Belkin website link below:
http://en-au-support.belkin.com/
I hope this is helpful to you, please rate it. Regards,
Sep 26, 2009 | Belkin F5D7234-4 Router
Belkin Wireless Router won't connect to ADSL
Turn off your modem and your router. Turn your modem back on wait for 2 mins then turn on your router. Try to connect. If that does not work. Connect your computer to the ADSL directly and check if you can get on. if not call your ISP.
Jul 27, 2008 | Belkin (F5D5231-4) Router
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
