Question about Homelite Mighty Lite Lawn Trimmer
Have a homelite grass trimmer crank ok run ok will trim grass for about 2 minutes then stop if you crank it and run for few seconds and the give it the gas it will not take gas just stop have replaced both gas tubing to tank,filter,air filter, spark plug, put in new gas will run only for few minutes. then just start slowing down till stops even if keep giving it gas by pulling on gas feed.
  • Homelite Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Testimonial: "hunter 19_46m expert thank you for replying to my question by putting in new gas (even though the gas in it was good , put in a different brand) and letting it run seems to have corected the problem. although i did see a split in the priming bubble and replaced it also. than again for the help... vision158"
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Need to find where air cleaner is ?
If your unit has one, it would be in front of the carburetor. Some Ryobis and Homelite trimmers do not have an air filter on them, just a screen inside the choke cover.
Sep 08, 2011 | Homelite Mighty Lite Lawn Trimmer
What is proper gas/oil ratio for homelite grass trimmer
Generally 2-cycle engines use ratios of 32:1 to 50:1. As a rule if you start with 40:1 you should be O.K. If your concerned that it might be to lean then start with 32:1 and if it smokes too much add 25% more gas to make it a 40:1 ratio.
Aug 02, 2010 | Homelite Garden
My Homelite grass trimmer idles fine but when I open the throttle it stalls. How do I fix this?
Its sounds like it is running rich. Adjust your high speed adjustment screw. If the unit is older think about buying a carb rebuild kit, they run about $12.00 at your local fix it shop and if you are not in a hurry online for about $8.00 give or take S/H.
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a practically new Homelite String Trimmer (model #UT20006 25cc) that has been sitting in the box in my mother-in-law's closet for over 3 years. It will start up like a charm. Fairly easy to crank in...
If all those items you mentioned are ok, then check the Air filter! If it's been sitting around, it may be plugged up or it may have insects that have built nests inside...
Also, there should be a fuel line back to the tank for pressurizing the system... Make sure the gas cap is tight, and the return line is snug in the tank.
Jun 03, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Trimmer won't start
they were in/out.
Please rate me, Thanks
May 13, 2010 | Homelite Mighty Lite Lawn Trimmer
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
String Runs Out
You are most likely keep bumping the head on the ground, causing the string to unwind. Hold weedtrimmer off the ground.
Jun 02, 2009 | Black & Decker String Trimmer Cordless 12"...
Homelite Mighty Lite Lawn Trimmer  Logo
304 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
