Question about HP LaserJet 4000 Printer
Connection accessory interface connectors 14 pin can I use that connection to connect with a Laptop
    Genius:
  • 3,587 Answers
Only if your laptop has that many pins..most are 9 or 25 pin connections, in my experience..
Posted on Mar 25, 2008
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Teac diskette drive pinout for Technics kn1000
Sorry.
There was an interface included, inside the KN 1000 unit floppy disk drive. This interface change "the 34 pin out from the floppy disk)" to "the 24 pin out" that could be connect to the the KN 1000 "24 pin in" conector jack in the KN 1000 main board.
As we know, the common disk drive unit in the market have 34 pin out only. wa can't connect directly 34 pin out floppy disk drive to the 24 pin in jack connector inside the KN 100o main board.
We need such an interface. This is the problem coz no one sell this interface separately in the market.
If u have one KN 1000 floppy disk drive unit (SY-FD), u can pick out that interface from inside the unit, and use it as a gate/interface from your new floppy disk drive to the "24 pin in" connector inside KN 1000 main board.
U can search this 24 pin out diagram interface in the net, but the problem is no one sell it separately.
Jun 20, 2012 | Teac IBM USB Portable Diskette Floppy...
Need to connect my J-NAV 500 GPS to my laptop, however, manual doesn't help much regarding which wires to to which pins on the 9 pin "D" connector. Thanks
This device if the manual is right uses an RS232 connection, what you are goiung to look for is a nine (9) pin connection it will look similar to your VGA connection on your computer. Do not connect the cable to your VGA connection, the nine pin connector will connect to the gps unit and the other end of the connector will connect or at least should connect to your computers com1 one connection or maybe the usb connection not sure. Should note that this unit has been dicontunued and the only manuals i could find were in Japanese which i don't speak, but that should be your connection.
Hope this helps
Jun 26, 2011 | JRC Plot 500F GPS Receiver
Teac external floppy disc drive will not format floppy disc
U need an interface, if u want to use the "34 pin out" from floppy disk unit, to the "24 pin in" connector jack, inside KN 1000 main board.
U can get this interface unit bboard from "the KN 1000 floppy disk drive unit".
Just open this unit SY-FD20, and pick out that interface board from this unit,
Then use it as interface to connect your new 34 pin out floppy disk drive to connecting to the 24 pin in connector jack inside the KN 1000 mainboard.
Feb 06, 2011 | Teac IBM USB Portable Diskette Floppy...
Where can you bay usb cable for panasonc ds 55 camcorder to connect to pc.
This camera downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is usually used only for stills. This camera doesn't have a USB connection at all.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. However, while most PCs have a USB port, they seldom have a Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Jan 24, 2011 | Panasonic NV-DS55B Mini DV Digital...
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
http://en.wikipedia.org/wiki/SATA
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
(NOTE*
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1281807&CatId=1455
Jan 06, 2010 | Compaq Computers & Internet
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
I need a DV cable so I can download my movies from my JVC Camcorder, but my laptop has the USB interface only. Can someone help me find a DV Cable with a USB Interface at the other end? My laptop only...
your camera has a usb connection : wal - mart has general purpose camera to pc cables ( bring your camera to confirm connector size ) also on ebay can get accessory kit for jvc dv cameras .
Aug 05, 2007 | JVC GR-D370 Mini DV Digital Camcorder
HP LaserJet 4000 Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
