Question about Sewing Machines
Hello I just got a new home My Lock 334D machine. It has Seized intermittenly. could we troubleshoot the problem & fix it together?
    Genius:
  • 1,116 Answers
Un-thread and then see if the machine will run without thread.
If not, it needs to go into the shop for repair.
If it does, refer to the manual. Or, the guide that should be printed on the inside of the serger's door.
Raise the thread antenna to it's highest position. Keep it at this position when serging. If lowered for storage, and threaded, be sure the thread does not tangle around the antenna arms.
Raise the presser foot.
Open/set the tensions to zero.
Raise the loopers to their highest level - there may be an indicator mark on the side of the serger to match with a mark on the handwheel to help with this.
Start threading from the right to the left; upper looper first.
After threading, reset the tensions to a medium number, lower the presser foot and stitch a chain to test the stitching.
Serge a scrap and adjust the tension as necessary.
Once you get the serger working as it should - don't run out of thread. Tie off, open the tension, raise presser foot and gently guide the new thread through the threading process.
When changing the thread or removing the thread to store the serger, cut the thread at the antenna, leaving thread tails for tying off the new thread.
If you do not have Nancy Zieman's "Serge with Confidence", you will find it much more informative than the average serger manual.
Posted on May 02, 2010
How do I set my Bernette 334D to overlock thin T-shirt material?
Thin, light-weight fabrics present some issues with sergers, ie the fabric tunnels with the stitching. Usually, it is better to use a narrow seam. Also, a stabilizer (wash-away) or even adding a strip of thin paper (toilet tissue, adding machine tape, etc) to the seam will help the fabric hold its shape when stitching. I have also sprayed & ironed heavy starch on thin fabrics to help stabilize.
sewing patternreview com
Serging Chiffon and Other Slippery Fabrics
Make It Handmade Understanding Your Serger Features
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Jul 02, 2016 | Sewing Machines
Presser foot lever won't raise presser foot
Here are some tips for a jammed presser foot:
A bit of lint-thread fluff in one or more places a home sewer can't reach to see much less safely clean. This is a job for a professional the first time so they can show you how to clean the inside of the machine without getting a very nasty electrical shock, and how to get the machine apart, cleaned, and back together with sewing functionality intact. (TIP: don't - don't - don't use 'canned air'! It will only push any lint/fluff deeper into the machine)
OR: the machine hasn't been switched back to sewing mode after winding a bobbin on the machine (simple fix you can do at home - check your user guide and be sure all of your settings are correct).
OR: a broken gear inside the machine (usually the bobbin gear but sometimes a different gear, and sometimes it's two broken at the same time).
OR: the machine has 'seized' because it hasn't been serviced regularly. This is a job for a professional - they will have the knowledge and tools to open the machine safely, find the problem and fix it, and then put the machine back together so that it will still sew.
Best of luck, I hope you and your machine are back sewing soon!
Apr 25, 2016 | Sewing Machines
334d
Time for a new foot pedal. The one you have is shorted.
Apr 11, 2014 | Baby Lock Sewing Machines
Bernette 334d
could be a short, having the machine checked would be a good idea.
The hand wheel & the overlock machine 14SH654 cannot move
so nothing is moving at all either by pressing the pedal or turning the hand wheel? Can you hear the engine humming or is the light working okay?
If yes, then this could be a gear failure inside the machine and not something easily fixed. Is this a oldish machine that has either had a lot of work or been sitting for a while? Has it been serviced at all in the past?
My Bernina 334D failed and it was a nylon gear in the main drive area which I had replaced but the dealer wasn't keen to do it, they wanted to sell me a new one. However, I checked with Bernina themselves that the part was available and how much, then talked to a local repair guy and he did the job for me. About 1/3 the cost of a new one though.
I'd suggest you take it to a Singer dealer and ask for a quote and find out if this is what has happened to your machine.
Mar 19, 2011 | Singer 14SH654
I need a manual for janome Mylock 334D please
The manual is located on the manufacturer's website, here. Click "Specifications" then "Download Manual. It is a PDF.
http://content.janome.com/index.cfm/Machines/Sergers/MyLock_634D
Mar 13, 2011 | Janome MyLock 634D Mechanical Sewing...
334d Bernette Overlocker
went to local berinina shop and purchased booklet for 10.95 aus dollars
thankyou feona
Jun 14, 2009 | Bernina Sewing Machines
I need to know the proper tension of a Janome 334d Mylock.
Check there is no thread caught in the tension units and set them ALL to 3 for the Factory setting......try a sample.....if it looks good, OK, if not, try to balance it by gently altering the knobs on the right (loopers) until they form an even tension in balance with each side of the fabric.
May 24, 2009 | Janome MyLock 644D
Sewing Machines Logo
370 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
