DVD Recorder/VCR 80 GB HDD
EWH100F Recording errors 03-50, and 03-56. Plays Dvds just fine, but if I try to record from any mode... always recieve these recording errors. 03-50 pauses play while recording from HDD. 03-56 stops recording function.
  • coriward Apr 12, 2008
    I have the same problem. All of a sudden one day, I just couldn't record and dubb anything. Recieving same error codes 3-50 and 3-56. What do they mean? How can this be resolved.
Tyr using -r dvds ,,,,,that might resolve your problems
Posted on Oct 07, 2008
I have been dubbing DVDs in high speed in SP mode successfully, but am not able to do so in LP mode. My DVD recorder shows error everytime whenever I attempt to record a DVD in LP mode.
There's a setting to record in high speed mode and I suggest you always do that. If a recording in SP doesn't fit on a standard disc I think you will find it won't dub at high speed either
Sep 16, 2010 | Panasonic DMR-EH60 DVD Recorder/HDD...
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd recorder turns off after 25 sec of recording. plays dvds just fine. what could be wrong?
hello,
read one of the other 'fixits' and applied it to my situation. i opened tray, turned off the machine, then pushed the tray half way in. used air and completely blew out the unit. (as well as can be expected w/o opening.) it now works.
it was very weird. it would shut off exactly 25 seconds after starting recording every time, at least 10 times. another weird thing was that it played dvds just fine.
thanks for help,
orin300
Nov 23, 2009 | Symphonic WF803 DVD Player/VCR
How to record dvd in ordinary format?
I will presume it plays back fine on your dvd recorder.
In this case, you need to "finalize disc" for it to be playable on other dvd players.
Also, possibly, If you are using a dvd-ram disc, you must make sure that the dvd-player you are trying to use even supports dvd-ram. Most will NOT.
Also, Make sure you are not recording in VR mode. Only some very new dvd-players will support VR mode discs.
Jun 01, 2009 | Pioneer DVR-550HS HDD Recorder
The dvd recorder and it hdd can't record since hdd full
Miss Fouzia Morocco
pls try to format all HDD first backup ur data by connecting the dvd recorder to pc then format ur hdd it will help lemme know
Feb 20, 2009 | Funai PY90DG DVD Recorder
Copying to hdd problems
Its not easy to copy a DVD, unless you have the proper software. Even then there is a lot of trial and error that you have to go thru. My suggestion is to findout whats the recording software that are used by both of the recorders and try to get around them by means of a computer.
Or alternatevly do the recording via a computer.
May 19, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
