Question about Roper REX4634KQ Electric Dryer
Replace the electric cord
I had to change the orginal cord to a three wire now I have to put it back to a 4 wire or Prong to fit the wall socket I do not remember where the wire goes. ex black, red, white and green. which goes first and etc. also I do not know where to place the green cause it has only three screws
thank
Sandra oestreich
  • Roper Master
  • 528 Answers
IT doesent matter :) just make sure the green connect to the boddy of your dryer.
Posted on May 02, 2010
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
Change cord on estate whirlpool dryer to fit outlet in wall
If this is an ELECTRIC dryer, the following link explains how to install either a 3-prong or 4-prong power cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If this is a GAS dryer, the standard color code for a three prong grounded plug is:
BLACK - HOT
WHITE - NEUTRAL
GREEN - GROUND
If you have any questions, please post back and let me know. I hope this helps you.
Jun 23, 2011 | Estate Dryers
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
I am replacing a 4 prong cord which is red, white, black, green with a 3 prong all black cord. My stove is a Maytag which was originally wired with a 4 prong pigtail for use in a trailer. I want to replace...
Okay, without knowing everything I would need to know; here's what I propose you do. First of all, are you exchanging the same wire size cord (eg. #12 stranded wire for 20 amp, and #10 for 30 amp, #8 wire for 40 amp,  # 6 for 50 amp, and so on) for the same application (ie. 30 amp for dryer, and 50 amp for range, etc.) ?  Let's say you are, so what you want to do is take the 4 prong off (one by one), and write down the configuration and color, as you take off each wire. And then you're going to apply this to your 3-prong plug. So, without seeing the plug and its application - I'm going to explain to you how to wire this. First, put the black (hot leg) wire will go on one of the straight prongs - and the red (the other hot leg) wire will go on the other straight prong. Now cut the white wire down to about an inch, so it can fit into the plug when you're putting the cap back on. And remember to tape this white wire with electrical tape. This is for many reasons, but its basically for safety. Now, the remaining wire (green) goes to the right-angled prong - which is your ground wire. Now your wired for 240 volts, and depending on the size of the wire - your wire size shall be in accordance with the amperage that I explained earlier. Now make sure that your power is off at the panel before you plug this oven plug into the wall. Then, turn the breaker on, then off. If everything seems okay, plug the cord into the wall (with the oven off) - and then turn the breaker back on. Then proceed to turn your oven on from there, and then if everything checks out okay, then your good to go. Good Luck with this, and I hope this works out for you. If not, feel free to contact me again. - Jim
Apr 05, 2010 | Ovens
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Conect 4 wires to 3 wires box in the wall
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Aug 18, 2009 | Whirlpool LER5636P Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Roper REX4634KQ Electric Dryer Logo
104 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
