Question about Philips Magnavox 20MS3442 20" TV
All of a sudden the remote is not working properly-it skips channels, I cannot use the numbers to select a channel, I cannot control the volume with the remote, I can't even turn the TV no or off. I have changed the batteries. Do you know what the problem is?
  • gb4741 May 02, 2010
    Yes, very
  • 10,594 Answers
There are two possibilities for said problem.
Either remote is defective or remote sensor in tv got bad.
You can test remote easily with help of any digital camera or even mobile phone camera will do the job. Watch remote front through digital camera and press few buttons on tv remote, you will observe infra red led blinking on remote front. That will confirm that remote is working and problem is with remote sensor that is mounted in front of tv.
If infra red led does not blink while watching remote through digital camera that means remote is defective, buy another remote.
Hope this info will help you.
Thanks.
Posted on May 02, 2010
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
Oct 18, 2014 | Sanyo DP19649 LCD TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Channel memory reset
Bryan,
Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
Nov 05, 2007 | Sharp 27K-S300 27" TV
Philips Magnavox 20MS3442 20" TV Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
