Question about Pioneer DV-270-S DVD Player
DVD-270 has picture but no sound...it appears to be plugged in correctly and the CD portion has sound...but not the DVD portion. I just moved and it was working this morning at my last house but when I plugged it all back in, no sound.
    Sergeant:
  • 418 Answers
Check in DVD player setup menus for audio output type of PCM or bitstream, etc., and try different modes. Probably reset when unplugged.
Posted on May 02, 2010
Trying to reset dvd pioneer 270 out of progressive mode and nothing is working can hear sound but no picture
I just had that same problem with my Pioneer dvd player. I found the online manual for my dvd player. For restoring the default settings simply turn off your dvd player, then press the STOP button on the front panel of your dvd player while turning the dvd player on again.
Sep 05, 2011 | Pioneer DV-270-S DVD Player
It will not load cd or dvd it keeps coming up
The loading mech or poss. the read portion of the disc player is out of whac. In other words the cd dvd portion of your deck is defective and short of having it repaired by a techinition there isnt much you can do. Its a **** shoot but you may be able to unplug the unit let it set for a few minutes and plug it back in may rest the mech., but like I say its a **** shoot. Sounds like its time for a new deck or a trip to the repair center.
Jul 30, 2010 | Dual Electronics XDVD710 Car DVD Player
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
No sound from the tuner
almost Has to be antenna problem. Id get a standard arial, plug it in and stick it out the window. If that works then you know what to do.
May 03, 2009 | Car Audio & Video
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Only plays one track from from DVD sound
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Jan 10, 2009 | Televison & Video
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Oct 01, 2008 | Toshiba 32D46 32" TV
No Disc
Initially, try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
If none of the above solves the problem, then chances are that the laser wiould require replacment. Considering the cost of repair and downtime, it might be more economical to purchase a new unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | Pioneer DV-270-S DVD Player
Have an AVR-2807 with a Toshiba DVD and Harmony remote. Havent played a DVD for a while and tonight when I try, I get picture and no sound. If I move the input to CD I get sound but I lose picture. ...
Have you changed the connections recently? If so, maybe something got plugged back in differently.
Otherwise check the AVR-2807's System Setup. There is a menu to associate different video inputs to each of the audio inputs. Probably the input with sound doesn't have the right video input associated with it, though I'm not sure you can associate a video input with the CD input... which tells me maybe the connections got changed?
Apr 05, 2008 | Televison & Video
Pioneer DV-270-S DVD Player Logo
106 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
