Question about John Deere Classic Two-Cylinder Tractors
The battery lite comes on when started then slowly grows dimmer the more i mow then mower shut off but engine still runs this is a j d gt 275
  • John Deere Master
  • 8,404 Answers
Your battery is dying ... it doesn't have enough power to keep the clutch engaged. You may have a charging problem. You can check this with a volt/ohm meter.
Posted on May 01, 2010
My walker will mow for a short time but will stall if I dont turn off the blades
if it has an electric clutch to drive the blades, it is possible that the charge rate of the unit is insufficient to run the clutch and the ignition and so the battery gets to a point where the ignition suffers
have the windings of the clutch checked for resistance and failure
Apr 02, 2016 | Garden
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Apr 04, 2014 | Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Craftsman gt 5000 blades quit turning
is there a wiring rubbing on metal?is a safety switch failing?
Apr 16, 2012 | Craftsman Garden
I need to install a new drive belt on a GT 275 Belt broke while mowing. Got new belt but it is not obvious how it goes on.
lay under the mower and look for a diagram - there should be one somewhere on the unit.
Gary @ Fix Ya
Sep 19, 2010 | John Deere Hood Gt242gt262gt275 Garden...
I have a 275 GT garden tractor with hydrostatic trans mission the fluid got low an would not move I bought fluid from dealership an installed fluid moved back an forth went to check level would not move is...
If the fluid was low and the mower stopped moving the hydrostatic will most likely need rebuilding or replacing. If it only started slipping changing fluid migh have saved it. You can jack up the rear with the tires off the ground and let it run in gear for a few minutes then do the same in reverse. Do this several times if it can be saved it will start pulling slowly when it does make sure it is still full of fluid let it down and drive it or mow with it. It could just be an air lock in the trans.
Aug 16, 2009 | John Deere Garden
Scotts mower kohler command 25 motor bogs when mowing
Hi..my name is Keith..and it sounds like you have a binding somewhere on your mowing deck..i would check all the spindles .. pulleys and blades..and check the deck belt..it could have jumped a belt guard and it running on the outside of it..but just remember it has pulley brakes to slow the pulleys down when you shut it off..so..engage the deck without the engine running and check for the binding..i hope this has helped..if not..please write me back
Jul 14, 2009 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
John Deere Classic  Two-Cylinder Tractors Logo
121 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
