Question about Euro-Pro Shark 80 - 7133
Lower bobbin looping
Model 464xc
    Genius:
  • 1,116 Answers
The top thread is loose and the bobbin thread is pulling the top thread down
Always thread the machine with the presser foot up and see if this eliminates the problem.
Sounds opposite of the problem, but it is very important to do this to assure the tension control can keep the top thread at the correct tension to form a proper stitch.
If the machine is threaded with the presser foot down, the tension control is closed and the thread cannot seat into the control as it should.
Posted on May 02, 2010
How to adjust lower tension bottom bobbin elna junior sewing machine passap?
On any machine, the lower - bobbin tension is adjusted with a small screw driver, used on the very small screw on the side of the bobbin. "Righty, tighty, Lefty - Loosy." If you stitch an inch of fabric, and the bottom loops come up, then... tighten the bobbin holder. If the loops pull down, loosten it.
Nov 25, 2017 | Elna Sewing Machines
Silver 302 sewing machine
If it is your top thread looping then the top thread is too loose and you need to tighten the top tension. Usually the higher the number the tighter the thread. If it is the lower thread looping to the top then try loosening the top thread first by lowering your tension number. If this doesnt work then depending on whether or not you have a separate bobbin case, which has a small flat screw 3-4mm diameter which can be turned by the flat of your thumbclockwise to tighten, if looping and anticlockwise to losen. Normally only the top tenison needs to be fiddled with. If you have to change the lower(bobbin) then one way of checking a good tension is to let the bobbin drop whilst holding the thread and it should drop comfortably with a small pull on the thread a little bit like operting a yoyo:)
Mar 27, 2014 | Sewing Machines
Kenmore 158 12271
the bobbin case is not located properly. take it out check the bobbin fits fully inside it.
Feb 18, 2014 | Sewing Machines
Top tension has to be turned all the way down to get good stitch, then thread gets caught in bobbin and lower hooping on thread..
Grab some scrap fabric of the same type you'll be sewing. Tighten your top tension and test sew until you see until you see the top thread of a seam go like a straight line and the bobbin thread loops on top of the seam. Then back off of the top tension until those loops disappear.
If you never see it the top thread go like a straight line... your top tension needs to be cleaned... and make sure you have the pressure foot UP when you thread the upper thread.
Aug 03, 2012 | Sewing Machines
The lower thread is getting tangled. I have changed the bobbin, re-wound the bobbin thread again, taken the bobbin out and cleaned the bobbin case.
Incorrect threading of the top thread can also cause lower loop tension problems. As can the wrong size or blunt needle. Try re-threading top thread first.
Dec 21, 2010 | Brother Sewing Machines
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Europro 464xc Sewing Machine
Dear frend!
I bought EURO-PROX 464XC with broken hook, but I know about broken part only now ( one and half hour after perchase ).
Could you please tell me where I can buy this part of this sewing machine.
I am an engineer and I can repair this machine myself.
I am old (71 year) and I don't speak English well . I am learning English in ESL school now
Please, excuse me my mistake.
Thank you.
My Best Respects to You
Galina
Aug 30, 2008 | Euro-Pro Fast and Easy 420 Mechanical...
Euro-Pro Shark 80 - 7133 Logo
190 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
