Question about ViewSonic N3735W 37 in. LCD TV
#7Viewsonic 37' will not power on
#7" viewsonic, just went off by itself. The green light comes on, but the unit will not power up beyond that.
  • 80 Answers
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
My viewsonic N3751w 37 in, tv will not power on
Is the status LED light on at all, if so what color is showing? if the LED doesn't even't light up, then the power supply is gone. Also, have you try using another power cable?
Dec 03, 2013 | ViewSonic N3751W 37 in. LCD Television
The light went off on my house and when the electricity got back my lcd viewsonic 32" N3252 doesn't turn on also the Red light is off any ideas
When power suddenly goes off from the main source, it tends to damage a component or the other inside a unit, because it was sudden and the unit did not go through a proper shut down process.
If your unit does not come on, and there is no sign that power is coming in, then it means there is a power problem, because there is no power supplied to the unit.
First try to plug the television to another another power outlet to see if it works, then try using another power cord, after doing that, also try to plug the cord to you HDMI port, if it does not come on still, then it means the power panel is faulty and needs to be replaced.
Take care and good luck.
Oct 28, 2010 | ViewSonic N3751W 37 in. LCD Television
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Phantom on/off
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance let me know where to contact you.
Aug 11, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Viewsonic N3760W won't power on
Try unplugging the set from the AC power source wait for several seconds and then plug it back in. Cross your fingures and hope that the reset works!
Feb 25, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
HP won't power up
Your main board is having a problem.
Nov 16, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic N3735W 37 in. LCD TV Logo
365 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
