Question about Minka Concept II Flush 44 Ceiling Fan by Aire
My Minka Aire remote control fan will not turn on--fan or light. The elctrical connections are all secure. Thr dip swithches are correct. How can I tell if it is my remote or receiver that is bad
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: Minka Aire remote controlled ceiling fan
I have the same problem, except I live in a multi unit condo where many of the occupants own the same fan! You can imagine how  frustrating this is when your fan or light comes on or you can't  agree on a fan speed. Anyway, I spoke to a MinkaAire customer service guy and he tells me that the switches in the receiver are located under the mounting ring. You need to unscrew the ring and it should be located in there. I haven't tried this myself as my fan has a mind of its own as I type and everytime I turn it off to unscrew the mounting ring, the damn thing turns on again.
Posted on Sep 04, 2008
SOURCE: Minka aire ceiling fan
My Minka Aire remote is not working. When I use the remote nothing happens. When I turn on the switch using light switch nothing happens. I had it installed two years ago. Battery never replaced.
Posted on Jul 17, 2009
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
  • 377 Answers
SOURCE: 3 concept II fans
According to the URL at: http://minkagroup.net/Admin/UploadFiles/F518-English.pdf there are dip switches on the fan. They are on the receiver that is most likely tucked away in the bell housing at the ceiling level. Pull the bell housing down and you will find a box of sorts that has the switches on it. This is the receiver.
If this solution is helpful to you, I would appreciate a Thumbs Up rating. Thank you, Paul
Posted on Oct 14, 2010
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
I have a Minka Aire Concept 1 which has been programmed to operate from a different frequency than nearby fans with remotes. The light goes on and off by itself at will and goes off each and every tim
Does your neighbor have a remote fan? Check wattage of bulbs to make sure they're the correct wattage. Still not working correctly, call 1-800-307-3267 (Minka Aire)
Sep 20, 2014 | Minka Aire Ceiling Fan
Minka aire wall control
Check to make sure the light wire is connected on the receiver. Also, If it is an add-on remote & you have a pull chain attached to the light, pull the pull chain for the light, Then try the remote. Otherwise, you probably need a new receiver.
Mar 01, 2014 | Dryers
Our electrician left all the dip switches in the same position for three fans. So now if someone turns on a light downstairs the light goes on upstairs. All we have is a remote, no wall switch from Minka....
Why not give your electrician a chance to do the job right but from your description I beleieve your electrician is confused between wired and remote control operation
Apr 11, 2013 | Minka Aire Ceiling Fan
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
We have a Milano Model No. F527 fan. The light comes on spontaneously at random times and the fan can only be turned on and off sometimes. Other times it works perfectly. The remote control batteries are...
Get in touch with Minka group Mr. Minka who will assist. I'm working on my same problem right now. You need to reset the dip switch in your remote or wall switch and also the same setting on the fan.
Jun 29, 2009 | Minka Aire Ceiling Fan
Minka aire f602
There are tiny dip switches on the remote as well as on the receiver. Make sure they are set to the same sequence. The receiver is the black box that all the wires connect to in the ceiling.
Nov 02, 2008 | Minka Aire F602-BNCH Gyro? Fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Aug 22, 2008 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Dryers Logo
130 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
