Question about Hitachi 46F510 46" Projection HDTV
Can see the black border lines down the sides of screen
When I'm not watching HD programming I leave the TV set on Normal, So the screen has the black border down each side. The problem is now when I am watching HD on normal I can still see those lines very faintly,like they are burnt in there. I also can see my satellite program guide ever so slightly in the back ground of the program I'm watching
    Sergeant:
  • 395 Answers
You now have burn in of the crt's. this happens when you leave a static image on the screen for long peroids of time (more than 15% of your total veiwing time per week). you should limit the time you use the pillar bars to less than that. this is not repairable but over time it will fade. stop using the pillar bars for a long wile or it will get worse. the only cure for this is to replace all three crts (costly repair).
Posted on Mar 25, 2008
SOURCE:
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
Picture is not as crisp as plasma should be.
The only thing you can do really is check your television settings to make sure its set up correctly and the satellite settings. Also if your watching analog channels through your set there gonna look fuzzy and distorted with blotches sometimes and also remember the bigger your tv the further back your supposed to sit if you stand right infront of it you'll see everything the way its not meant to be seen. after you try all that make sure your using either component or hdmi cables for the best picture.
Jul 07, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
I can't get the full screen on some hd channels and during commercials. It goes from full screen viewing on some channels to the picture shrinking and having a border around it.
There are a few picture sizes out there 4:3, 16:9, as well as some for movie screens. New televisions are 16:9 and when you are watching a true HD program, it will fill the screen perfectly. However the program may be broadcast in one of the other formats. This results in the bars on top/ bottom or on the sides. This is true for commercials too. If the commercial is or isn't in HD will determine if there are bars or not. All this is normal operation.
Apr 20, 2011 | Televison & Video
I am getting black borders top & bottom on some channels and side to side as well on Fox on my Dish Net receiver 322 to analog TV.
Hey there! Becki Barned from Dish Network customer service here. The black borders are usually caused by watching standard definition programming on a high definition television. Try to change the format on your tv. Either by pressing the * button below the 7, or trying a format or display button on the original tv remote. Hope this helps!!!
Aug 21, 2010 | DISH Network 322 DTV Receiver
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
LCD T.V. burn-in question.
I can assure you that LCD burn in CAN and DOES happen! My frequently-viewed Futures Trading software has left a ghostly image of the toolbars, menus, and window borders on my ViewSonic 36" LCD flat-screen.
Apr 24, 2008 | Televison & Video
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Hitachi 46F510 46" Projection HDTV Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
