Question about Crown CTS600 2-Channel Amplifier
Input 60Hz hum
Crown CTs 600.
The amp works...that is sound comes out, albeit with 60Hz hum.
Hum only occurs when the minus & the ground input pins are connected together, which is neccessary when using an "unbalanced" input.
If a source is connected "balanced", the hum is barely noticeable, but still present. (The balance circuitry is doing its job...as well as it can)
With nothing connected to the inputs, shorting the minus and ground pins causes very loud 60Hz hum.
If nothing is connected to the inputs, there is no hum.
If I had a schematic and or the service manual I think I could find the problem. Without it, it's nearly impossible, due to the board being SMT.
Any help would be greatly appreciated.
Thanks,
Chuck
    Scholar:
  • 75 Answers
I had the same problem once and in my case i had accidentally used ground wire for signal. pls check ur connections again. one check u can do is set the high pass filter to 70Hz and see if that cuts out the low hum.
Posted on May 02, 2010
Bose av18
Hum is tough. It is often caused by quite a variety of things. First, address the basics:
1. Make sure that none of your signal cables run near to power cabels.
2. If possible, feed all power from the same receptacle.
3. If your plugs are not polarized, try reversing one at a time.
If none of those basic checks uncovers your demon, verify the path of the noise by disconnecting the signal from the preamp at the input to the sub. If is still hums, then look closely at the power feed to the sub, More likely, the hum will stop (along with the music.) In this case, try breaking the shield ground at the sub input (e.g. with a ground isolation adapter.)
You should also confirm that the hum is limited to the sub. Subs tend to exaggerate hum because playing signals in the 60Hz is their forte. So with the sub turned off and bypassed, listen for the hum in your main speakers. If it is there, too, then start checking your sources. Remember, even a source device other than the one selected for play could be the source ... completely disconnect each source at the preamp to track it down.
Aug 03, 2014 | Bose Audio Players & Recorders
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 | Music
My Bass is not working it is only making a humming sound
Most likely a cable problem - that hum is likely 60hz hum from an improper ground connection. The cable between the sub and the amp needs to be checked and repaired or replaced.
Jul 23, 2012 | KLH Audio Players & Recorders
Hum when mixer is turned on
If it is a 60Hz or 120 hz hum, the fault may be a bad solder connection to a filter capacitor in the power supply.
If it is a hum like a bad mic connection, you may have dirty contacts on an input, dirty tracks on a mixer control, even on the EQ portion.
It may also be a bad cable is connected, or a 1/4 inch jacked input may not be grounding out when the plug is removed. You may have a bad ground on the power feed and you have a ground loop as a result, or a cable is faulty and creating it's pwn ground loop to something else.
Contact cleaner is not a bad idea, slide pots are notorious for spurious noise over time. LPS1 is not bad, but it does use silicone as the dry lubricant portion.
If all of that is ruled out, look internally for bad solder joints- anything that looks crumbly is suspect, and also check for loose wires and jacks with bad solder connections. Also look for loose connectors too.
Mar 29, 2012 | Mackie 3204VLZ3 32-Channel USB Mixer
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
How do i hook a numark tt 1625 turntable to a regular home stereo amplifier...does the ground need to go into anything specific?
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Feb 26, 2011 | Numark TT1650 Turntable
Humming noise when volume over 40
This hum could be from a ground loop or a bad main board in your TV.
1. Try removing all the inputs from the back of the TV.
2. Unplug the TV for about 3 minutes and plug it back in.
3. Turn on the TV and go to HDMI1 input.
4. Turn the volume up to see if you hear the hum.
5. If you hear the hum without any inputs into the TV, then the problem is with your main board, or with the quality of power you have going to your TV (your wall outlet may have an open or bad ground). You can try plugging the TV into a different outlet across the other side of the house (to try a different circuit) to see if your power is the problem.
6. If you don’t hear a hum without any inputs into the TV, then the audio hum is caused from one or more of your inputs.
7. You will have to plug in one input at a time into the TV, and turn up the volume to see if that one input is creating the hum. If the TV hums, then you have a problem with that device and or the cable that connects it to the TV.
8. There is a chance the hum will occur when two or more devices are connected to the TV at the same time. So be careful of this issue. This issue is not the fault of the TV and is a grounding issue between the devices.
I hope this information has helped you.
Good Luck.
May 28, 2010 | LG 32LG30 32 in. LCD HDTV
Miller & Kreisel Subwoofer 60Hz hum
This is a common problem.  The potentiometer is damaged and needs to be replaced.  Potentiometer is a fancy name for volume knob.  It's a $5.00 fix if you know what you're doing.
Dec 01, 2007 | Audio Players & Recorders
Toshiba 3387DB Television
it is due to 60Hz HUM IN POWER SUPPLY. please check for input supply. also check for mains filter capacitor in tv. also check for one diode open in rectifier ckt.
Oct 02, 2007 | Toshiba 3387DB TV
Crown CTS600 2-Channel Amplifier Logo
270 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
