Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool ultimate care ii gas-I found the fuse, but have never seen a fuse like that. It is white just like the online diagram., but it seems to be intact. how can i test it? thanks
    President:
  • 949 Answers
It is a thermal fuse, it trips by temperature rather than too much electrical current. You can test it with an ohmmeter. If good it will read 0 ohms (needle moves all the way over), if bad it would read infinite ohms (no needle movement)
Posted on May 01, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
    The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
    May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care will not stop spinning
    I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
    Hope this helps _MJ_
    Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Drips from center of front cover when filling at 3-4 inches
    after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
    Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    How do I take off Whirlpool Washer cabinet to get to the pump
    Ultimate Care II LSQ9564J
    Go to;
    http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
    click on your model number. The new window will give diagrams in the left-hand side.
    Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
    Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Cant find the fuse on my ultimate care II dryer?
    The thermal fuse is usually white plastic about 3/8" wide and about 1 1/4" long
    Mar 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Ultimate care II Whirlpool dryer
    yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
    May 24, 2008 | Dryers
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Washer fills but agitator doesnt start; sensor problem
    very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
    Sep 24, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool GGQ8831L Gas Dryer Logo
    128 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
