Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I have a 03 seadoo 4tec need to know where the oil drain plug is and how to change the oil
    President:
  • 1,978 Answers
The place you add the oil is the place you take it out . You will have to get a fluid pump either operated by hand or by electric drill. Feed the tube down to the bottom of the oil sump and pump the oil out into a container. I would recommend a pail or bucket with quart or liters marked so you can measure how much oil you have removed from the motor. When you are sure you have taken out as much oil as you can, change the filter and pour in the fresh oil . Be careful not to over fill. If you put in too much oil , take some back out.
Posted on Sep 10, 2010
How do i drain the transmission on 03 fxdl, i want to change the tranny fluid and i want to know where do i drain the fliud.
From the drawing that I'm looking at, the transmission is drained by removing the drain plug on the right rear of the oil pan. The other drain plug is for the engine oil and it appears to screw up from the bottom of the pan on the right side. If you have changed the engine oil, you know which plug drains the engine oil, it's the other one.
Good Luck
Steve
Nov 13, 2010 | 2003 Harley Davidson FXDL Dyna Low Rider
I have a 03 classic and I want to change oil , it has 2 plugs and a temp sensor
The engine drain plug is the forward facing plug at the lefthand front end of oil pan.
Nov 01, 2010 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
I wont to change my oil and filter. where is the drail plug on my 03 heritage softtail clasic?
I'm not familiar with every year model but most of the time on a Softail, the oil drain is a hose that runs down the frame on the right side of the bike. It ends down low just behind the transmission. There is a plug in the hose, remove the plug to drain the oil.
Mar 28, 2010 | Harley Davidson FLSTC Heritage Softail...
1994 nissan pulsar import. Need to know how to do a oil change thanks
remove oil pan drain plug, drain oil. check gasket on drain plug re-install drain plug , fill oil to correct level.
Aug 12, 2009 | 1990 Nissan Pulsar
Oil drain plug location and oil filter location 03 cadillac escal
The oil drain plug is close to the radiator area underneath the Escalade. And the oil filter is a standard screw on type which is clearly visable from underneath.
Jun 13, 2009 | 2003 Cadillac Escalade
Trans oil change
Run the bike until it's at operating temp. Locate the drain plug. On the oil pan right under the transmission. remove the plug using a 1/4 allen. Fully drain. replace plug ( I suggest applying Teflon tape on the threads to make sure you won't leak ) then put in 23 ounces. runn the bike back up to operating temperature, then check level with bike upright and level.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Apr 22, 2009 | 2003 Harley Davidson FXSTDI Softail Deuce
Oil change specs
the engine takes 4qts w/filter and the drain plug is 17mm.
Apr 12, 2009 | 2001 Hyundai Elantra
Oil drain plug leaking
go to the auto parts store they will sell you a self tapping over sized plug that will work great but you need to bring the old plug with you. i just did one on a 03 caddy cts
Mar 10, 2009 | 2002 Volkswagen Jetta TDI
Need diagram where oil plugs are to change oil on a 1998 harley electrc glide classic
the oil drain plug is on the bottomof the oil tank under the bike it is a bolt with an allen bolt hole in the middle going from frnt to back the tranny bolt goes straight up in about the same spot and the primary is the small torx fastner at the bottom of the primarry cover
Feb 19, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
226 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
