Question about MSI K8NGM2-L Motherboard
AMD 64 Hello I have a AMD 64 when turn on the power button the computer turns on but there no screen like in mother board boot up screen could anyone help me please
  • Leonardo Garcia
    Leonardo Garcia May 11, 2010
    HI flat69. Do you hear any beeps?
  • 186 Answers
Sound;s like a connection problem unplug to reset then try it again ok;
Posted on May 02, 2010
Forgotten my computer access code
If you are referring to the power up access code screen that comes up when you first turn on your computer, it can be erased by removing the disc type button battery located on your motherboard. Make sure computer is un pluged from the power source. Remove the button battery for 30 seconds. Re-install it and power the computer up. It will boot up normally. If you are referring to a lock out of your Operating System, you will need to purchase a password recovery / reset program and load it into your computer during start up using the boot drive options selections located in your start up / set up menus. Its usually called: Boot Options or Boot Drive Options
Jul 14, 2014 | X2 Systemax NO OS AMD Desktop Computer -...
Tip
How to get a computerto boot when it only has a black screen
Hello there everybody<br />Have you ever turned on your computer and hear that it was booting but all you got is a black screen and nothing else?<br />Well here is a simple tip that i have used on literally hundreds of support calls <br />(1) First when this happens power down the computer. <br />(2) unplug the computer from the wall and remove the power cord from the computer.<br />(3). open up the case of the computer.<br />(4). find the wires from the power supply going to the mother board<br /> and remove it from the mother board.<br />(5) now press in on the button that u use to turn on the computer for <br /> 20 seconds this allows for the ESD to be released , if you have a <br /> reset button do the same for this button too.<br />(6). replace the power supply cord onto the motherboard and plug in<br /> the power cord back into the computer <br />(7) plug in the computer and start up the computer .<br /> <br /><br /> Now you should be good to go the reason that this <br /> Happens is that Esd builds up in the system and overtime it will <br /> prevent the monitor from displaying. but once the esd has been <br /> discharged the (PROPER) WAY then it is taken care of ok <br /> <br /> I hope this tip helps you all out <br /> Best regards Michael<br />
on Jan 22, 2011 | Computers & Internet
Can I use P4 478 processor in K8V-MX mother board
You can not use intel ,It is a athlon platform Mother board.
Follow the link, and you can know every thing from here.Just click here.
Hope it will help you.
Regard's
Shibuda.
Dec 31, 2010 | ASUS K8V-MX Motherboard
Asus mb wl300 amd 64 4000+ won't boot to bios.
To make sure it isn't anything else, pull all cards, and drive cables from the board so the only thing left connected is the power connectors to the motherboard, the speaker, and the power button. Pull all the ram cards.
Now power up the computer. If you hear a series of beeps then the computer recognizes there is no ram on the board. At this point I would take the power supply out and have it tested. If you do not hear a series of beeps I would still have the power supply tested as it could be the 12v is fine but the 5 and 3.3 volt side is bad.
If power supply tests good then I would replace both the motherboard and processor. You take a risk of burning a new processor if it's the motherboard causing the problems.
Jan 08, 2010 | ASUS Computers & Internet
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Doesnt boot???????
The best way to troubleshoot this is to start over.
Strip the board bare and add components one at a time.
Do the Power supply and CPU fans spin?
The fact that two boards have done this suggests that some component is faulty or installed improperly. It's not impossible to get two bad boards, but it seems unlikely.
Oct 22, 2007 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
MSI K8NGM2-L Motherboard Logo
75 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
