Question about Musicmatch Jukebox Deluxe v8 for PC
Trying to intstall Musicmatch. Just keeps saying "Please wait for setup to configure the installtion" and doesn't do anything. Have tried on two different computers, same result...any ideas?
I'm trying to load musicmatch 10 to window 7 64 bit i keep getting missing px.dll file
download the px.dll file from http://www.dll-files.com/px.zip?0WMgQDZIfU and then copy it to your Musicmatch 10 folder.
May 02, 2011 | Computers & Internet
MusicMatch Jukebox 10
I have same problem a few months ago, even i reinstalling musicmatch but problem still exist, what I have done is reinstalling windows and install musicmatch again, now its work for me.
Jun 12, 2009 | Gateway Computers & Internet
KEEP GETTING ERROR 321 WHEN SETTING UP LINKSYS WRT54GS ROUTER
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 17, 2009 | Linksys Wireless-G Broadband Router
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
Configuration interrupted
you may need to go into F8 safe mode to continue this process
Jun 15, 2008 | Acer Computers & Internet
MusicMatch won't work with Vista
ya from web site direct till they offer a nice vista download u have to wait it willl be very soon next week or so
Jan 26, 2008 | Musicmatch Jukebox Deluxe v8 for PC
Musicmatch Jukebox 10.00 .4040 Full version unable to connect to the internet
Has any MMJB subscriber found another music program that permits line-in recordings, similar to MMJ?
Dec 20, 2007 | Musicmatch Jukebox 7.0 (1575956454) for PC
Phillips pss110/05
hello, i found the original cd that came with the mp3 player, uninstalled musicmatch and pss device manager, disconnected from the internet and reinstalled everything on the disc. i then reformatted the device and had to go into settings on the portable device option in musicmatch and selected pss 110 rather than flash. the device works now although i had to select the 'add' from portable device rather than sending to it from musicmatch jukebox.
hopen it works for you. you may have to keep selecting the pss option as it seemed to re-set itself as a flash device a few times. john
Dec 12, 2007 | Philips PSS110/17 MP3 Player
Seeing files in musicmatch jukebox
Musicmatch is now cancelled - Oct 2007
Jan 23, 2007 | SanDisk Sansa e260 MP3 Player
Musicmatch Jukebox Deluxe v8 for PC Logo
19 people viewed this question
Top Musicmatch Computers & Internet Experts
Alun Cox
Bill Boyd
Are you a Musicmatch Computer and Internet Expert? Answer questions, earn points and help others
