Question about Microsoft Xbox 360 Console
Problems with disk tray
My disk tray keeps on getting stuck while it trys to slide out..and sometimes it will slide out with no problem..any idea on how to fix it?
  • 186 Answers
There ia a runner it slides on make sure it is not cracked'
Posted on May 02, 2010
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
Im having problems removing the DVD drive from the laptop. The sliding button underneath appears to be stuck. Any ideas? Patrick
Remove the screw that holds the DVD drive in(bottom about five inches in from DVD door). The tray is in, take a paper clip and put the end in the hole of the drive door to release it. Gently pull on the tray and the whole drive should come out. Hope that helps..
Jul 14, 2011 | Computers & Internet
Paper goes in sidewides and gets stuck when it trys to print
Sometimes you need to clean the rollers that pull the paper through the printer. There could be a piece of paper torn off stuck back there that causes any paper going through to jam.
Also, make sure the paper sits tightly in the feeder tray but not so tight that it bows.
Apr 13, 2011 | Dell A960 All-In-One InkJet Printer
Drive tray keeps opening and does not read disk
Do you mean it will not stay closed?
if that's the case the (closed leaf switch) in the
drive is shorted together . gotta open it up
to fix it . that normally happens when someone
trys to open it up with a thin screwdriver.
If the laser was good (reading games) before the tray problem
its still good.
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
DVD DOOR TRAY JAMMED (MRD 200 MAGNAVOX DVD SURROUND SYST)
That's an old unit!!!! Reboot is what happens when you shut the computer down and then turn it back on. This is not exactly a computer but it does have a processor and it does require the same treatment. You'll probably have to pull the plug too, for a minute or so.
If this doesn't help, you probably have a broken tray mechanism, either mechanical or electronic failure and repair is iffy and probably not worth the money.
Sep 03, 2009 | Philips 0603 magnavox mrd200 System
I can't print from tray 2 or 3 from either Mac or PC
You need to remove the trys affected, most likely there is a sensor issue.
Remove the trays and check behind them as paper sometimes falls behind blocking the sensors. If so, remove the paper.
Also, check the paper slides in the tray themselves, remove the paper and slide them in and out all the way, put the trays back in the machine and put the paper back in the tray moving the slides right up against the paper and close the door. It should work normally from now on, if not try a reboot one more time.
Mar 26, 2009 | Xerox Phaser 7700DX Laser Printer
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
Buttons dont work any more.
In many cases, the drive motor that moves the disc tray in or out becomes inoperable. It may get a signal to activate, but it is stuck in position and will not function. Yes, you can manually force the tray to open, but noting you can do will help make the tray go in/out using a button or remote.
The entire unit needs to replaced, unfortunately.
Jan 13, 2018 | Toshiba MD9DM1 9 in. TV/DVD Combo
CD tray opens only when there's a CD in it
Hi nolights
The disc clamp usually has a magnet in it so I would sugest the loading belt is slipping and therefore the motor can't overcome the clamp force.
A new belt should cure the problem
John w
Dec 21, 2007 | Audio Players & Recorders
DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Mar 26, 2007 | Bose 3·2·1 II System
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
