Question about KLH CDR2000 2-Disc CD Recorder
How do I record a CD from an album on a turntable?
    Brigadier General:
  • 8,546 Answers
Assuming you have a functioning turntable either self-pre-amplified or through a component (such as a receiver or integrated amp) with an internal Phono preamplifier just connect the self-preamplified TT directly to the analog inputs on the CD Recorder; or connect the CD Recorder to the receiver / integrated amp as if it is an analog tape deck (which it functionally is in this case).
Posted on May 02, 2010
How to best record to computer
For the software I would recomend Magix Audio Cleaning Lab. You should find several different versions on Amazon.
Jan 29, 2013 | Stanton STR8-80 Turntable
Hi - I have been recording some of my vinyl albums onto CD's for several months now. All of a sudden, when I went to use the turntable yesterday, I can't get the Record light to light. What am I...
If the red indicator on the record button does not light, reload a record-able dics, wait a few seconds until "NO TOC" and "CR-R" (or "CD-RW") indicators light on the display, and press the record button again. BE sure your using the CD -R or -RW disc and make sure to use a disc bearing the "Digital Audio" mark on it.
Richard Roth
The FixYa Team
Aug 09, 2011 | Teac GF350 Turntable
Software says if I continue, it will record in mono. How do I switch to stereo? I'm recording from an album to my computer, and onto a CD-R.
Maybe the software is only detecting one channel. Try checking your connections. Don't forget the wires to the cartridge.
Jan 03, 2011 | Numark ttUSB Turntable
How do you record a cd from tape on crosley cr2406a
Set the function to "phono" and record it the same way you would an album.
Dec 01, 2010 | Crosley CR248 Turntable
I have purchased a turntable with ez audio converter. I record one side of an album and it says recording complete. I click next and after a minute the software opens itunes and says converting temp1. Wait...
You can record the entire album, both sides without having to press next. When the entire album has been recorded then press next, you will a dialog box that allows you to name the album and songs. Make sure you have the most up to date software from the ION website- that is if you have an ION turntable. Go to ION website and locate your turntable- software will be on that page. Run it and it should correct any problems.
Dec 22, 2009 | ION Audio iTTUSB Turntable
ION USB recording mainly room sound, only little album sound!
Sound input option was routed to microphone in System Preferences. Needed to change it to the turntable input.
Feb 19, 2009 | ION Audio iPTUSB Turntable
Crosley CR2406A will not record CDs properly.
I had this problem when recording CD-Rs. I switched to CD-RWs and didn't have the problem again.
Feb 18, 2009 | Crosley CR248 Turntable
Proper cleaning of old vinyl record albums
Get yourself a nice carbon fiber brush. Purchase some record cleaner or just get some isopropyl alcohol 90% (it has less impurities). Secure the arm of the turntable so you don't scratch the record and put the record on it. Put some of the cleaning solution on the brush..not the record. Put the brush on the record and turn the platter counter clockwise to work the dirt loose. Check the brush and clean it if need be and repeat. Take the record off and clean the turntable. Flip the record over and repeat the cleaning process. That should do it. Thanks for stopping by and come back if you need more help. If you don't mind, rate my answer appropriately. Thanks.
Jan 19, 2009 | Vivitar ViviCam 10 Digital Camera
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
KLH CDR2000 2-Disc CD Recorder Logo
124 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
