Question about Microsoft Xbox 360 Console
BadColour I just got an xbox 360 today i connected to my phillips hdtv using the 6 colour coded wires tht came with it yet yhe Colours are worng e.g. yellow is white, red is pink...... PLEASE HELP!!!!!!
Switch the av cable to hd setting
Posted on Mar 25, 2008
Got a new xbox 360 and kinect, have to change my tv settings to play the games i have but then get a very different picture with very dull colours
Ah, this happened to me when i got a 360S. You have an old 360, no? And you used the HDTV conmponent? Go to the console settings, and fool around with the display a bit. You'll find what you want. Just make sure you're using the OLD 360 cord or an HDMI cord; the new ones are **** and only designed to work with extremely old TVs.
Jan 30, 2011 | Microsoft Xbox 360 Console
I only want to know the meaning of the different colours of cables that are used in crossover cables?
the standard colours for CAT5(e) or CAT6 ethernet cable are:
green, green stripe
blue, blue stripe
orange, orang stripe
brown, brown stripe
the typical setup for an ethernet connection in an RJ45 (the crystal end with the connection tab towards you) is
2 green
3 orange stripe
4 blue
5 blue stripe
6 orange
7 brown stripe
8 brown
Wires 1 & 2 are used to transmit data from the PC to the router/modem (TX) and wires 3 & 6 are used to recieve information from the modem/router (RX). in this fasion, information flows along one pair or another and is expected to arrive at that pinout. the router/hub/modem takes care of the transition to the next cable or out to the internet.
In a crossover cable ONE end is configured as above, but the colours for wires 1, 2, 3, and 6 are exchanged so that when no hardware is between the two PCs/components the signal is transmited at wire 1 & 2 and recieved on pins 3 & 6 on the other system/component. the other colours are placed for backward compatibilitiy and other applications, such as power over ethernet.
following the standard above allows anybody familiar with RJ45 connections repair a connection with a standard colour code and pattern without having to see the other end. If you know you need to replace one end of a patch cable, you use the standard termination.
Oct 12, 2010 | Computers & Internet
Xbox-360 wireless controller doesn't sync at all
my xbox e87a2ee.jpg joystick this spot of cable is broke and i dont know what is sequece of colours in cable?
Oct 23, 2009 | Microsoft Xbox 360 Controller
Xbox 360: colour/display failure
most likley a cable issue if you are using hdmi make sure its fully homed in same with the others but have you checked the display settings on your xbox? otherwise borrow another cable just to find out
Aug 06, 2009 | Microsoft Xbox 360 Console
Distorted Colours
your graphic card is going out
Jul 11, 2009 | Microsoft Xbox 360 Console
Hooking up vga cable on hdtv cannot get any sound
okay in the back of your tv there should be 3 rows of places you can put the things in the top should have 3 colours and if you plug the av cable in to them slots you get a great picture but no sound in the row below there should be a red port plug the red one in from the other set of colours (white, yellow,red) and you will get solund hope i helped please give me a good vote =]
Dec 24, 2008 | Microsoft Xbox 360 Console
No picture on 360 with white dotted lines.
Make sure that the video connection is properly connected to the TV.. (yellow to yellow) or if using Red Green Blue, make sure colours are connected to the right ports on back of TV)
Also, if you have the option, make sure either HDTV or Normal TV is selected on the back of the connector to the Xbox (IE, if you do not have an HDTV, select normal cable).
Apr 10, 2008 | Microsoft Xbox 360 Console
Colour quality
Sounds like your xbo360 has an hdtv setting turned on which your tv doesn't support.
Feb 23, 2008 | Microsoft Xbox 360 Console
HD Connections
try using the scart tht came with the xbox i had this prob first time but its quiet easy 2 fix
Dec 29, 2007 | Microsoft Xbox 360 Console
Xbox 360 no audio
if you are using the component cables supplied with the unit, there should be two plugs that you don't use, if you have them all in then thats why theres no sound. double check the colour coded plugs as you may have connected the wrong one as there are 2 you dont need to use
Aug 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
