Question about Kitchen Ranges
My LFD22860 suddenly died. I cleaned the coils, checked the electrical outlets, plugged and unplugged it. Nothing. Any thoughts?
    President:
  • Kitchen Ranges Master
  • 2,923 Answers
Since you verified that there’s power from the wall socket to the refrigerator, and it’s still not running, then your problem lies in a different area. You’ll want to check the power cord, compressor, overload/relay, thermostats, and wiring, or contact a professional appliance repair person.
Thank you and good luck!
Posted on May 02, 2010
Car won't start
Did you check your timing belt?
Jun 27, 2014 | 1989 Chrysler LeBaron
Whirlpool cabrio
got a error code, was there a power surge before this happened? If not then you can assume that your LED screen died. Unless your good at electrical issues, call customer support and see if they have a easy troubleshooting guide for it. If not, then you will need a new screen for it to make it work.
You can check the power outlet, try plugging your dryer/washer into the other plugin, see if it works or doesn't. Might be that. Or use a DMM "digital multimeter" (if you know how) and check the outlet.
good luck
Apr 30, 2013 | Washing Machines
Cuisinart DBM-8 coffee grinder started by itself.
Mine did it as well. I had an electrician out to check out the outlet. He replaced the outlet, but it still has done it. It freaks me out, so I unplug it after use.
Nov 02, 2012 | Cuisinart Supreme Grind DBM-8 Electric...
The whole unit switches off after about 30 minutes. I thought it could be heating up and cleaned the fan (externally), put it on 1/2 inch brackets to ensure air circulation, changed to a different...
If you suspect thermal issues maybe you could verify that the unit actually feels hot when it dies. If not, it's some other cause.
Is the now-clean fan working?
I'm sure the manual of this unnamed component might give some clues as well as what the proper physical clearance around the unit should be maintained.
Aug 03, 2010 | Audio Players & Recorders
Traeger 075 tripping GFI continually
May be too much moisture on the hot rod.
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Jun 19, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Nissan 300zx 5th cylinder died
do you have coil over plug or one coil? if you have spark plug wires, swap one with the cylinder in question. swap an injector.
Mar 01, 2010 | 1990 Nissan 300ZX
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Ground fault as soon as I plug it in.
You more than likely have a dead short in the compressor
Nov 15, 2006 | Maytag M7DH65B2A Dehumidifier
Kitchen Ranges Logo
12 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
