Question about Whirlpool Duet GHW9150P Front Load Washer
We keep getting a "suds" code and then an F35 code
  • 299 Answers
? If too much detergent was used: —Run the unit through a Rinse/Spin cycle. —Run a Normal cycle without adding any detergent. This should clear the unit of the excess detergent. 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU). 4. Check/clean drain pump filter of foreign objects. 5. Plug in washer or reconnect power. 6. Check drain pump. 7. Check the pressure switch. 8. Verify CCU operation by running a Diagnostic test or any cycle.
Posted on May 02, 2010
Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
I keep getting either SUDS or the F35 code. I finally was able to get it to run so I ran it without detergent. Now I tried it again and it is back to SUDS again. Any ideas?
ok...run unit on rinse and spin only,,we need cold water,,if unit still shows sud error make sure drain hose is not kinked,,,if we still have a sud condiction or error ,,remove toe panel and clean filter.good luck
Sep 07, 2011 | Kenmore Elite HE5t Washer
Suds, and F35 keeps coming up when trying to wash!
I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
Jul 26, 2010 | Kenmore 44102 Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting f35 code on quiet pak 9 washer
F35,= SUDS
set a few washes without using any soap to flush the pump out.
Use less detergent and use a liquid rather than powder.
Aug 25, 2009 | Kenmore Washing Machines
F35 on whirlpool duet ht, tech came out and reset board a few days back...same problem again this morn....talking about a switch. Can you Help
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Aug 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
